d16z6 need help with bottom block build
Old Nov 26, 2009 | 12:01 AM
Homotor's Avatar
Default d16z6 need help with bottom block build
im in the process of getting my bottom block built, i was just wondering if i can use supertech block guard with darton 75mm sleeves, will it work? what setup do u guys think will be good for my block? i just need it to hold the boost im plannin on pushin about 15-20psi, i will be using standard bore cp 9:1 pistons, eagle rods, arp studs, will be tuned on hondata s300, stock head, sc44 precision turbo, ramhorn rc 650cc injectors... hopin for mid 12s on 22's this will be goin into a 92 vx hatch by the way..
Old Nov 26, 2009 | 04:29 AM
Autoworks's Avatar
Default Re: d16z6 need help with bottom block build
Don't use a blockguard.
Also if the block has been used before w/ a 75mm piston, then I'd suggest going with 75.50mm (.20 over)
Old Nov 26, 2009 | 08:15 AM
VTECJUN's Avatar
If your goal is to run 15-20psi may I ask what your HP goal is? What type of fuel will you be running?
Old Dec 2, 2009 | 11:46 PM
Homotor's Avatar
as far as hp im hopin for somewhere in between 200-300hp on 91 octane, and also, will i have to notch the block for the rods?
Old Dec 3, 2009 | 03:06 AM
Autoworks's Avatar
That stock sleeves are capable of holding that amount of power easily.
Yes, you will need to notch the block w/ H Beam rods.
Old Dec 3, 2009 | 07:30 AM
Boosted-EH-804's Avatar
No need for sleeves at the level spend that money on some head work and a cam plus invest in a quality turbo kit. Hit up RCautoworks they can get you what you need
Old Dec 3, 2009 | 10:42 AM
Fo-Do Fanatic's Avatar
Notching the block? What?
Old Dec 3, 2009 | 10:45 AM
kyden's Avatar
you have to notch the bottom of the cylinder for h-beams in a d series.
Old Dec 3, 2009 | 11:17 AM
Homotor's Avatar
if i used stock sleeves will it last long and be good for daily driven with good tune on low boost?
Old Dec 3, 2009 | 02:29 PM
welfarepc's Avatar
yes
my times are on stock sleeves, i DD'd the car all summer, put over 8000km on it
Old Dec 4, 2009 | 12:04 AM
Homotor's Avatar
nice, well i'll probably just go ahead and boost the stock block for now and get it street tuned on low boost, till i decide what i want to do... thanks for the info guys!
thugsbryan
Mar 27, 2015 09:48 AM
Vt3c_eg
20
Jan 22, 2010 08:42 AM
Homotor
Nov 26, 2009 12:01 AM
blinx9900
Jul 21, 2007 11:50 PM
Snail Tuning
Jan 23, 2004 07:50 PM
