B20 with GSR crank: Yes, I know it will fit, but...
Old 11-24-2009, 06:29 AM
integrawow's Avatar
Default B20 with GSR crank: Yes, I know it will fit, but...
Are the chamfering's and radius' the same such that I don't need a crank shop to modify these parts? I'm refering to the crank main bearing radius' and the way it will mate to the B20 block.
Lastly, am I wasting my time with the B20 block with stock sleeves? I mean, I will more than likely spray a little nitrous.
Old 11-24-2009, 06:46 AM
I'm not Rick!
rick_rabies's Avatar
Default Re: B20 with GSR crank: Yes, I know it will fit, but...
a shop will definelty need to spin that crank and do what you want to it.
sleeeeeve it or bbbrrreeaaak it
Old 11-24-2009, 06:56 AM
official honda whore
EARLdaSQUIRREL's Avatar
everything will bolt right up, just make sure all clearances are good
and sleave it if you want to put any decent amount of power through it or nitrous at all imo
Old 11-24-2009, 12:03 PM
STEEZY_EG+DC's Avatar
i'm doing this set up. i got a gsr crank cp pistons and eagle rods for pretty much free, just picked up the b20 block a few days ago just need bearings now.
Old 11-24-2009, 01:30 PM
EFPhilly's Avatar
LUCKYYYY. Im doing this set up in a B18A1, with stock acura new bearings, all the plastiguage checked out just fine, so I think It should be fine, ive heard the B20 is a LS with just a bigger bore (84mm)
supra-n-civic
08-10-2009 07:44 PM
civicswap
03-19-2006 05:27 PM
5w20
12-04-2004 11:57 PM
XSBoost
06-12-2001 10:46 AM
Quick Reply: B20 with GSR crank: Yes, I know it will fit, but...
