running different boost levels?
Old Nov 27, 2009 | 06:14 AM
95civhb's Avatar
Default running different boost levels?
Maybe a bit of a noob question, but here goes...
I had sent an email to the guy that I will get to tune my setup, and was wondering about running different boost levels (eg. high boost/low boost).
He uses neptune (which version I'm not sure) and he stated that this could be done through the use of a solenoid.
Just wondering if anyone can shed some insight on the subject for me, or redirect me to where I can find some good reading on the subject?
I realize for different tuning programs there are probably different options present for running different maps, I just don't know how the process works.
Old Nov 27, 2009 | 11:52 AM
boostedEF91's Avatar
Default Re: running different boost levels?
you can use the pwm boost controller with Neptune.. its a solenoid type controller that works through the ecu for boost by gear etc.... i had it but i didnt like it. fluctuated to much.. i would suggest buying a boost controller from www.j-k-tuning.com. there js boost controllers.. you can have a simple high and low boost setting just by flicking a toggle switch that you can hook up. or you can also run it through the ecu..
Old Nov 27, 2009 | 12:34 PM
95civhb's Avatar
I see what you mean as far as using the toggle switch, however, if I switch levels of boost by that method only, I suspect my a/f wouldn't be as it should be...
What do you mean exactly by "running it through the ecu"? Having a laptop with neptune running and switching bin (?) files?
sh!ft
Jul 8, 2011 07:39 AM
s2kkid
Jul 4, 2005 09:04 AM
nigel
Mar 24, 2004 05:29 PM
The Poopsmith
Dec 14, 2002 01:35 PM
