Inline pro manifold
Old Nov 9, 2009 | 02:38 PM
BoostedEgHatchFl's Avatar
Default Inline pro manifold
How big of a turbo will fit on the t3 ac manifold. I was thinking about running an Borg Warner S256 on a sleeved 82mm b16 motor.
Old Nov 9, 2009 | 06:25 PM
Turbo-LS's Avatar
Default Re: Inline pro manifold
im pretty sure unless you got the manifold for the 4bolt housing then you need to use a ford style 5 bolt turbine housing and an E cover. i think the largest turbo in that configuration is the sc6152e . i think the s256 is an E cover so you should be good
Old Nov 9, 2009 | 07:12 PM
averyvm's Avatar
when talking about that ford style five bolt is that the same five bolt configuration found on garret turboes?
Old Nov 10, 2009 | 01:29 AM
king06's Avatar
In for info, I also has this mani.
Old Nov 10, 2009 | 03:12 AM
Turbo-LS's Avatar
yes same 5 bolt that is on garrett turbos
J-Brooks
Nov 23, 2003 11:52 AM
Arturbo
Jun 22, 2003 01:27 PM
smslude
May 2, 2003 02:01 PM
integranator
Feb 5, 2003 03:51 PM
