map sensor
Old Nov 15, 2009 | 10:59 PM
avotegra's Avatar
Default map sensor
I have a 2.5 bar motorola and want to switch to a 2.5 omni bar....can i just switch and not retune or them both are not exchangable
Old Nov 15, 2009 | 11:23 PM
avotegra's Avatar
Default Re: map sensor
help please FIgeek
Old Nov 16, 2009 | 05:44 AM
miguel329's Avatar
i asked your tuner if someone doesnt respond. just to be safe.
Old Nov 16, 2009 | 06:01 AM
TurboChurch's Avatar
They are very similar, but not exact. Depending on the software used, you may not see any difference. But to be clear, they are different.
Old Nov 16, 2009 | 09:26 AM
avotegra's Avatar
i was tune on crome.....is there any difference....
Old Nov 16, 2009 | 10:03 AM
HiProfile's Avatar
It mostly has to do with the high vacuum area, specifically where the voltage cutoff is. It shouldn't make enough difference to be noticable, but it would be a good idea to check AFR's with a wideband. At most you'd just have to adjust the first two columns for idle.
Show15
91
Jan 5, 2023 08:48 AM
quickchris
Jul 28, 2006 09:47 AM
Topdawgg
Jul 1, 2006 08:22 AM
SleepinTeg
Apr 14, 2004 12:12 PM
VTC_CiViC
Apr 12, 2004 06:00 AM
