Anyone used Injector dynamics 750cc??
Hey im planning on running the injector dynamics 750cc on my B18c1 with a peakboost setup. Has anyone used these. Ive read good things about the 1000cc from Injector Dynamics but havent heard much about the 750cc. Will they drop right in the intake manifold or is there modification needed to the stock cushions for the injectors. Anyone that has used these or has any info on them would be great as i have searched and come up with nothing. Thanks
Re: Anyone used Injector dynamics 750cc??
The ID725's are every bit as great as the ID1000's. You'll love them.
They fit the manifold perfect with the stock injector cushions. If your stock cushions have been modified or are stretched out, they should be replaced. The part number for the OEM Honda cushion is in the instruction sheet that comes with the injectors, should you need some.
the 725cc ID's are sweet i tuned them in my friends car and he gets 30mpg, boosted
d16z6. wont go with nothing but ID's now
I've tuned lots of cars with both the 725's and 1000's. I've had a few cars where I could tell a very slight improvement in idle/cruise with the 725's, but for the most part, you wouldn't be able to tell the difference between the two.
Tony
I have a set of ID750's any differences between them and the 725?
Bought direct from T1 on 2/05/09
Sorry but your PM's are turned off
There isn't a 750, only 725. When we were doing initial testing we called them 750's but after doing larger qty they averaged closer to 725cc. You may have bought them very early on when there was a bit of confusion on that.
I liked the way the 1000cc ID's performed on my buddy's car I tuned. With a smaller injector you should have a longer duration of fuel for the lighter loads which should help make for a more consistent air fuel mix in the combustion chamber, but I wouldn't think that there would be much difference between injectors of this size.
just wanna ask if there is a thread on injectors performance (if they atomitize better or get u better mpg and power)
