problems w/ motor. help
Old Nov 14, 2009 | 06:19 PM
one slooow dc4's Avatar
Default problems w/ motor. help
this is getting on my nerves now, just got done rebuilding the motor go to fire it back up and it starts running really rich and dies if i dont open up the throttle body.
t3/t4 w/ ramhorn..
Type R JG bored throttle body
AEBS intake manifold
GSR motor
OBD 1 del sol si harness
all the sensors are hooked up properly.
TPS is good
MAP is good
Timing is dead on
firing order is all inplace
IACV is hooked up
AIT is hooked up....
i just dont know whats going on.. really odd... im a mechanic and have tried just about everything... even new plugs new wires etc..
if you have any thoughts or opinions feel free to add in what might be wrong.
once again the problem is : when it fires, runs rich, misses hard, and dies. (symtomps almost as if TPS or MAP was not hooked up or something.. but it all is)
Old Nov 14, 2009 | 07:13 PM
Default Re: problems w/ motor. help
bumppppppp!!!!!!
Old Nov 14, 2009 | 09:56 PM
ttt
Old Nov 14, 2009 | 10:16 PM
95civhb's Avatar
what ecu are you running? do you have stock injectors in?
Adam_b16a's Avatar
do you have the tps and the map sensor plugs mixed up?
Old Nov 14, 2009 | 10:21 PM
no i dont.
this is far beyond something that simple.
Old Nov 14, 2009 | 10:22 PM
tuned p28 on 440 dsm.
(run fine before rebuild)
Old Nov 14, 2009 | 11:57 PM
Adam_b16a's Avatar
They're 450's correct?
Have you done a compression check?
Old Nov 15, 2009 | 06:39 PM
440's
and i just got done assembling this motor and iv built many motors.
this is not a error of the engine because with the old intake manifold it ran like a charm
nuginu
K Series
Aug 17, 2013 11:26 AM
moemoney
Sep 7, 2011 10:33 AM
dc101
Jun 1, 2011 06:21 PM
m723tec
Engine Management and Tuning
Jul 11, 2010 09:00 PM
kechup2eg6
Aug 10, 2005 07:47 PM
