turbo doesnt have fitting for WG??
Old Nov 14, 2009 | 01:59 AM
Hoe Hopper's Avatar
Default turbo doesnt have fitting for WG??
Hey guys my garrett t3/t4 doesnt have a fitting for a line to the waste gate...Is there another way i can route the WG without having to tap a fitting into my turbo?
Old Nov 14, 2009 | 03:26 AM
_kiid's Avatar
Default Re: turbo doesnt have fitting for WG??
intake manifold.. or vacuum box
Old Nov 14, 2009 | 06:37 AM
TheShodan's Avatar
Moderator
Done... and done.... ;-)
Old Nov 15, 2009 | 11:01 PM
Hoe Hopper's Avatar
Thanks guys
Old Nov 16, 2009 | 07:45 AM
dpetro1's Avatar
other options are to drill and tap the compressor housing, weld a fitting on the charge pipe or run something like this http://www.atpturbo.com/mm5/merchant..._Code=ATP-FTG1
Old Nov 22, 2009 | 04:33 PM
IN VTEC's Avatar
I drilled and tapped for 3/8" NPT and used a 3/8" NPT -6AN orb fitting to feed a solenoid and the wastegate. I had to cut down the 3/8" NPT threads to reduce the amount of protrusion into the discharge path.
Old Nov 22, 2009 | 05:03 PM
boostedcivicsir's Avatar
Mr. Badwrench
21/64ths drill and a 1/8 npt, nipple fitting, done.
Old Nov 22, 2009 | 10:01 PM
Hoe Hopper's Avatar
Cool thanks guys
Nbboy7
May 23, 2010 02:22 AM
b18_integra
Feb 18, 2008 04:42 PM
.RTErnie
Dec 3, 2005 05:29 PM
pissedoffsol
Mar 26, 2004 07:04 PM
B18c1turboedEK
Mar 23, 2004 10:42 AM
