gt42 turbo
Old Nov 15, 2009 | 03:00 PM
s.cha's Avatar
Default gt42 turbo
is the garrett gt42 turbo too big for a semi-built ls turbo setup??
Old Nov 15, 2009 | 05:02 PM
TheShodan's Avatar
Moderator
Default Re: gt42 turbo
unless you plan to drive it at an airport runway, yeah.. I I can take a stab at this and say that using that isn't a good idea.
Old Nov 15, 2009 | 08:33 PM
V-SPEC 1's Avatar
With no Vtec head and stock bore, i would say to big.
Old Nov 15, 2009 | 08:53 PM
s.cha's Avatar
okay lets say this i'll use a b20b block with low compression forged pistons with eagle rods and a stock ctr head with gsr cams...now will it be good with the gt42 turbo?
Old Nov 15, 2009 | 09:14 PM
TheShodan's Avatar
Moderator
If this is being used as a type of street / occasional drag race car
Old Nov 15, 2009 | 09:16 PM
YARO.'s Avatar
Hell no, even worse if you use a b20 block. They don't hold any mayor power.
Can you please say whats your power goal?? a gt42r is a big power turbo. Like for sleeved built motor and 700++ whp goals.
Old Nov 16, 2009 | 04:31 AM
AROD's Avatar
i had an ls with the s372 and it ran fine. track car....went 10.1@148 straight LS set-up
Old Nov 16, 2009 | 05:29 AM
s.cha's Avatar
so okay the b20 is not as good as the ls block? and i am asking because i found a really good deal on 2 garrett gt42 turbos going for $100 each.. i have a garrett t3 turbo rite now but was wondering how the gt42 turbo will be like on the setup i'm planning on doing
Old Nov 16, 2009 | 07:04 AM
ScorpionT's Avatar
Its capable of 1000+whp, so if youre not making use of it, get something smaller. If theyre $100 each, theyre probably junk or not true Garretts, maybe Masterpower.
Old Nov 16, 2009 | 07:36 AM
YARO.'s Avatar
Maybe a broken ebay turbo for 100 bucks lol
Old Nov 16, 2009 | 08:20 AM
s.cha's Avatar
i talked to the guy already and they are still in good condition with no shaft play and they ARE garrett turbos
Old Nov 16, 2009 | 08:33 AM
TheShodan's Avatar
Moderator
Have you READ about the uses for the GT42 turbo? Do you actually have any idea how BIG that really is? You might want to read up on that. If they are true garretts, they are probably BLOWN turbochargers that were not worth repairing.
It just seems that you are truly clueless to the amount of air these use, so here's an idea. Most V8 high flowing 302CID engines can't run that on a regular basis, much less a Honda unless it is for drag purposes only.
Also, take a look at garrett. This is considered a LARGE frame turbocharger
http://www.turbobygarrett.com/turbob...4_731376_1.htm
Stop trying to do this on the ultimate cheap..you're just going to get ripped off if you don't understand the parts that you're attempting to purchase.
Old Nov 16, 2009 | 09:04 AM
IMPORTant Si's Avatar
Excellent Reply!! There is no better advice! If you want to go big enough to achieve 400 - 600 hp and be very streetable ( and occassional race), get a gt35r. IMO, one of the best "streetable" turbo manufactured. And can produce amazing numbers.
Old Nov 16, 2009 | 02:52 PM
s.cha's Avatar
hey thats why i asked for people here to help me out...but i'll just keep my t3 turbo for now...thanks for helping me out everybody
Old Nov 16, 2009 | 08:10 PM
boostedcivicsir's Avatar
Mr. Badwrench
the shodan tells it like it is.
arod may have had luck with it. he did say track car.
but using a gt42 on the street is pointless.
there are way better options for your power level and ultimate goal.
bigboom
Mar 26, 2010 07:00 PM
MyHotsh
May 16, 2008 11:03 AM
boblaw
Jan 29, 2008 04:45 PM
SkertySkerty
Jun 6, 2007 08:38 AM
jonyb
Dec 28, 2002 10:24 AM
