Compression Help
Old Nov 26, 2009 | 09:15 PM
Adam_b16a's Avatar
Default Compression Help
Recently got my b16a all put back together and i wanted to get a accurate compression ratio. Im using Wiseco low compression flat top 81.5mm pistons (K542M815) and eagle rods (CRS5290H3D) with a stock b16 crank. The block deck was milled 7 thousands with a stock b16a head. I did a compression test and i got 190psi across the board. I just wanted to know what my compression ratio is and what psi should i be reading.
Old Nov 27, 2009 | 04:08 PM
Adam_b16a's Avatar
Default Re: Compression Help
no one??
Old Nov 27, 2009 | 05:33 PM
D-Clem's Avatar
thats around 9to1 to 9.2to1
Old Nov 30, 2009 | 08:29 AM
EARLdaSQUIRREL's Avatar
official honda whore
its nearly impossible to tell exact compression with cc'n the head/block etc
and most compression gauges arent that accurate but what really matters is that the psi across the cylinders are even
Firstoost
Apr 26, 2006 05:30 PM
Thrashin
Aug 10, 2004 02:41 PM
K20 EG
Jun 17, 2003 11:26 AM
