Forged pistons clearances for street engine - experienced builders welcomed!
I'm in process of building D16 250HP+ supercharged engine that should be installed in my daily driver ('92 Civic Coupe).
As the car will be driven every day, I need my bottom end bulletproof as much as possible - drivability is also very important.
I'll be using Supertech forged pistons (75.5mm, Part No.4-HD755-N12) and I need to rebore my block - but I have to decide about piston-to-wall clearance...I've got specs sheet from Supertech:
They put only note about MINIMAL piston-to-wall clearance:
0.0023" or 0.06mm.
Is that really enough or should I go slightly looser?
I would really like to hear some more details from more experienced builders!
0.0023" or 0.06mm.
Re: Forged pistons clearances for street engine - experienced builders welcomed!
For what its worth, my goal is 300whp on my d16 and mine are at 0.003" with vitara's.
If you have an intercooled M90 eaton or centrifugal on there, .0030" would be enough. If it's a JRSC at least .0035".
My street D16 is at .0035", and I don't get enough piston slap to notice it. I even have a stock muffler after an e-cutout, and I still dont' notice it.
2 HiProfile:
Hm, I am going with M62 Eaton & FMIC - so my SC is sized between M45 from JRSC and M90...
After reading all this, I guess if I choose 0.035" I'll be OK with street D16 engine.
.0035" here and no excess noise, some catch can smoke but I gapped the rings for a high HP than my motor has so oh well.
lelopez
10-15-2003 02:49 PM
