high compression + turbo ????
Old Nov 12, 2009 | 09:03 PM
dailyekhatch's Avatar
Icon2 high compression + turbo ????
i got a stock ls motor with some p30 pistons. the previous owner had the motor rebuilt only 2k miles on it. i looked up on one of the honda motor build calculators. and the ratio came out to 11:0. i was wondering if i can turbo this motor. or i have to get it rebuilt agian with something around 9:1. but i really dont want to waste this motor. so can it be turboed at 11:0. the motor is a ls.
Old Nov 12, 2009 | 09:19 PM
coneheadsracing's Avatar
Default Re: high compression + turbo ????
Yes, get a good tune, and have fun.
Old Nov 12, 2009 | 09:28 PM
so the stock rods are strong enough to with stand 12psi? cause i know theres going to be alot of torque going on inside the motor.
Old Nov 12, 2009 | 10:05 PM
95civhb's Avatar
psi means nothing...
same psi on different turbos = different numbers...
guys do run stock rods... are they stock rod bolts? If you want some insurance, arp rod bolts are a good way to go...
depends on your goals.. if you want a monster, then build the bottom end..
Old Nov 13, 2009 | 07:16 AM
88aeFC3S's Avatar
find a bad-*** tuner...
BEAST/LS
Feb 15, 2016 10:09 PM
moosepoop21
Aug 11, 2006 12:38 PM
s2kkid
Aug 29, 2005 12:28 PM
jmcfkya
Apr 13, 2003 02:59 PM
