which bearings to use, D16
Old Nov 17, 2009 | 08:25 PM
My JDM EJ8's Avatar
Icon2 which bearings to use, D16
hey everyone, well im building my y8 block. Im using FJ 75.5mm vitara pistons with forge rods but im confuse on one thing. Do i get .50mm ACL bearings or standard siz bearings?
Old Nov 18, 2009 | 08:25 AM
My JDM EJ8's Avatar
Default Re: which bearings to use, D16
Anyone?
Old Nov 18, 2009 | 08:37 AM
NonovUrbizniz's Avatar
Loved
standard bearings... oversized bearings are for rod/crank clearances that are too loose.
the oversized pistons only determine what cyl. bore you have to run and what size rings to get.
Old Nov 18, 2009 | 10:01 AM
My JDM EJ8's Avatar
So just get standard bearings
Old Nov 18, 2009 | 10:40 AM
EFPhilly's Avatar
go to the dealership, spend the extra money for oem. Thats what I did.
Old Nov 18, 2009 | 10:45 AM
TorganFM.'s Avatar
Why? There's nothing at all wrong with ACL bearings.
Old Nov 18, 2009 | 10:55 AM
HiProfile's Avatar
What determines the bearing size is the crank journal sizes and the block's journal sizes. If it has only been micropolished, you get standard bearings, then use plastigauge to check the clearances. If they fall w/in spec, you don't need the OEM "color-coded" bearings used to correct clearance issues. A more precise way is to use a micrometer & snap/bore gauge to measure the room for bearings.
FYI If you've cut a stock Honda crank more than .0009", it's already removed the hard coating, and isn't worth using.
Old Nov 18, 2009 | 12:31 PM
Bond's Avatar
Listen to him. Also this better not turn into another ACL vs. OEM thread.
Let's keep that can of worms shut.
Old Nov 18, 2009 | 04:47 PM
My JDM EJ8's Avatar
so should i just take it to the machine shop and see what they tell me?
no this is not about v.s. i just wanted to know which size.
Old Nov 18, 2009 | 05:04 PM
welfarepc's Avatar
that is what i would recommend you do since you dont seem too confident on making your own decision.
Old Nov 18, 2009 | 05:07 PM
My JDM EJ8's Avatar
ya on something like that i really dont want to f*** up
Old Nov 18, 2009 | 08:55 PM
EFPhilly's Avatar
my bad, didn't mean to turn it into a discussion about oem vs acl; just go to the shop and listen to them I agree. I listened to my local shop.
goat86
Apr 19, 2014 12:00 AM
Jdm_Ej8_Sedan
Jan 29, 2014 05:34 AM
Charlie Moua
Jan 16, 2012 07:01 PM
boostedefhatch
May 13, 2010 11:02 AM
JayDM-hatch
Jan 23, 2008 09:27 PM
