Catch Can Advice
Old Nov 10, 2009 | 12:17 PM
E85B18's Avatar
Default Catch Can Advice
I searched for an hour and couldn't find what I need. I need a catch can for my 500whp build. Will a simple greddy catch can with 2 fittings on the top work? Or will I need to go with one with a filter to relieve more crank case pressure?
Old Nov 10, 2009 | 12:59 PM
NonovUrbizniz's Avatar
Loved
Default Re: Catch Can Advice
for 500whp you should be looking at something like tony1's
https://honda-tech.com/forums/performance-45/t1-catch-can-kits-2446266/
http://www.t1raceparts.com/en/produc...atch-cans.html
Old Nov 10, 2009 | 01:46 PM
E85B18's Avatar
Yeah, Ive seen that one. It's sick! Im just trying to spend around $250, are there any other options??
Old Nov 10, 2009 | 02:44 PM
rudebwoy's Avatar
endyn. @ www.theoldone.com or moroso @ www.sumitracing.com, or B&R sponsor on here. I personally use a T1 but B&R makes the same one cheaper.
Old Nov 10, 2009 | 02:57 PM
E85B18's Avatar
Thanks for the links. When getting emissions tested, do you think removing the stock PCV system will cause me problems?
Old Nov 10, 2009 | 03:03 PM
boostedcivicsir's Avatar
Mr. Badwrench
for your budget, the endyn setup works well. but it has its limitations.
the t1 setup is the cats ***.
as far as passing emmissions, it will probably run better but it depends on your state laws.
Old Nov 10, 2009 | 04:49 PM
jdm inc's Avatar
T1 ftw!!
Old Nov 10, 2009 | 06:09 PM
Loved
All depends on where you live.... tell us I'm sure others will tell you... you might also want to search for your state's name in the thread title and see what comes up... chances are there's an emissions thread somewhere...
If you only want to spend about 250. I'd really recomend getting the T1 can only... then just use barbed fittings on the valvecover and run normal automotive hose instead of a/n and braided steel hose.
Old Nov 11, 2009 | 08:41 AM
E85B18's Avatar
I live in Colorado so the emissions aren't as bad as California. Anyone have experience with this one? It's a B & R kit, Its $290 for everything shown:
Old Nov 11, 2009 | 08:49 AM
dpetro1's Avatar
That would work great for your setup. 2 valve cover ports and 1 block port/drain back. Also B&R has great customer service, ive ordered from him twice now.
i basically run that same kit except i added another fitting to the can so i could run both rear block ports. probably not needed but the more the better. also i run rubber lines/barb fittings for the block ports but stainless/an lines for the valve cover
Old Nov 11, 2009 | 08:57 AM
E85B18's Avatar
Sweet. I'd like the bigger one but its $500 like T1's. This will be better than the stock PCV system Ive been running lol. Do you happen to have a picture of where the drain goes back into the block? If there are two open ports on the back of my B18C, does it matter which one I use? Any reason why you used rubber lines?
Old Nov 11, 2009 | 10:19 AM
dpetro1's Avatar
either of the two ports can be used. once you remove the balck box there will be a port behind it. use that one since its closer.
i used aeroquip push lock fittings and hose purely because its cheaper. my valve cover lines pretty much lay on the turbo mani do i used stainless there
Old Nov 11, 2009 | 10:58 AM
miguel329's Avatar
B&R is only person id order from. great customer service
Old Nov 12, 2009 | 01:41 PM
E85B18's Avatar
I just ordered the B&R. Customer service has been good so far, we'll see how long delivery takes.
Old Nov 13, 2009 | 06:02 AM
miguel329's Avatar
good to hear you will be happy... which kit you get from them?
021_bennett
Jan 15, 2011 10:37 AM
VTEC_PRODUCTION
10
Jun 3, 2009 02:58 PM
MidwestCivic
10
Jul 14, 2007 04:37 PM
JM Performance
Jan 6, 2002 08:48 PM
Big Phat R
Oct 2, 2001 11:03 PM
