What kind of power SHOULD I be making?
I havent been to the dyno yet so I am curious what kind of numbers you guys think I should be pulling on this setup;
Turbo B18A obd0 stock bottom end
Mild head porting
Crower cams
T3/4 Turbo (not sure the exact specs) @ 10lbs boost
450cc injectors
Also, where is the limit on the stock bottom end?
Mild head porting
Crower cams
450cc injectors
Re: What kind of power SHOULD I be making?
the stock bottom end will probably take more then those injectors will put out... Ive seen personally a couple 300whp bone stock B18b's with a mild setup... but they used bigger injectors then that..
I wouldnt risk it
I wouldnt risk it
vtecgod
10-08-2007 12:41 PM
nokturnal_munkeeboy
04-24-2007 09:14 AM
Freeltec
05-04-2004 04:30 PM
