over boost baddd need help
Old Nov 17, 2009 | 07:21 PM
_kiid's Avatar
Default over boost baddd need help
ok i hooked up my boost controllor n it over boosting to 20psi n when i run it off wg its around 9psi.. its everytime i hook up a boost controllor it happen to me twice
can anyone help?
1st time with turboxs mbc
this time greddy profecb
both set at 0 but still overboost but when bc off n run wg spring its fine
ebay wg btw
helphelp plzzzzz
Old Nov 17, 2009 | 08:19 PM
TheShodan's Avatar
Moderator
Default Re: over boost baddd need help
You need to READ the directions of the Profec b, and be VERY careful when adjusting your boost settings. For god's sake don't FLOOR IT when testing.
http://www.alamomotorsports.com/gred...EC_B_SPEC2.pdf
Old Nov 17, 2009 | 09:07 PM
_kiid's Avatar
its turned off.. and when turned on i have it set at 0
Old Nov 17, 2009 | 10:15 PM
_kiid's Avatar
ya think its my wg? its egay lol
Old Nov 18, 2009 | 08:31 AM
_kiid's Avatar
anyone plz helpp?
Old Nov 18, 2009 | 08:35 AM
NonovUrbizniz's Avatar
Loved
If the WG works by itself and it's happened twice chances are you're hooking up the controller wrong.
Old Nov 18, 2009 | 09:43 AM
CRX T-Si's Avatar
http://www.fd3s.net/profec_install.html
There is a little insight on how to hook it up and set the dip switches.
Old Nov 18, 2009 | 09:53 AM
C2K_TB_TEC's Avatar
You will need the check the installation guide for the profec b...
Make sure the top and bottom ports on the WG is linked in the right way to solenoid and compressor, I recall seeing the link to the installation instructions somewhere in the FI section or you can get it from the greddy site..
I have profec b and 38mm Turbonetics evo 2 WG and I can hold 0.5bar on my setup.
Also make sure the % setting is low enough.. to get to it you have wait until you on the main display screen and turn the **** until you get it To below 10% for starters..
Theres 3 boost setup screens, the %, the set boost, the start boost.
The set gain in kpa or psi or bar value is not the actual boost setting..
Set the warning and limiter down to as low as possible try 9 or even 10 psi, if the settings are close enough to what you want there should be a response in holding the boost, or pulling it back down.
With "all" the settings low enough it should be able to hold a specific pressure, if not then the WG is stuft or solenoid is stuft or not installed properly..
By the sound of things it seems as the WG alone is holding, you have set both BC settings to 0...
mmmmaybe the installation.
http://www.greddy.com/tech/
Old Nov 18, 2009 | 10:02 AM
C2K_TB_TEC's Avatar
Just checked it out - very good info there : )
tnx
Old Nov 18, 2009 | 11:52 AM
_kiid's Avatar
it was working fine when i got tuned
its all hooked up right
i took the wg off n i hear something loose
Old Nov 18, 2009 | 03:08 PM
_kiid's Avatar
i fixed the loose bolt.. still does it even with a smaller spring..
n found a boost leak on the chrage pipe but that wont cause overboost
i guess ima just run it off wg..
Old Nov 18, 2009 | 03:45 PM
azandford's Avatar
buy a new wastegate
Old Nov 18, 2009 | 03:52 PM
_kiid's Avatar
you think its the prob.?
Old Nov 18, 2009 | 04:02 PM
azandford's Avatar
Well because you told me you got it form ebay and its a no name. You unfortunately cant expect them to work for very long. I had to replace my ebay wastegate and BOV.
Take the MBC off and link the pipes together, this way the wastegates are going to see the actual turbo pressure. Drive the car carefully on boost and check to see if it stays at 9 psi using your boost gauge, if it stays at 9 psi you know the wastegates/ piping is ok.
If it overboosts you know you have a problem with the pipes/ pipe routing or wastegates sticking, take a look at the sticker under the bonnet and make sure the vac lines are connected exactly the same as the diagram (it is confusing until you find your way around it!). After you`ve got consitant boost at 9 psi you can re-fit the MBC and tune it in.
Old Nov 18, 2009 | 04:12 PM
_kiid's Avatar
alright cool thanks
like i said it was working good before then one day i hit it **** overboost to 20 so i ran wg for awhile but felt to slow lol
turbotime
Sep 10, 2006 05:12 PM
slowater427
Oct 4, 2005 02:42 PM
integ2
Jun 15, 2004 06:44 PM
hXc-DC2
Oct 15, 2002 06:38 AM
