Ignition issue on my drag car, coil or ignitor?
Well I'm trying to decide what my ignition issue is on my drag hatch. After I make a full pass and the car is warmed up, if I shut it off in the pits and try to start it back up it will not start. I have to take a plug wire off and ground it as if I was checking spark, as soon as it arcs the car will start. Once in a blue moon the wire will arc across ground and not start, I can try it 5 mins later and it will. The car has never quit while running though. I want to say its the ignitor because of the way you get it to run but also I know coils take a crap when there hot too. I just wanted to see if anyone has ever had the same problem and what the solution was. The car is on Ectune if that helps in any way. Thanks.
Re: Ignition issue on my drag car, coil or ignitor?
If you have a stock dizzy you can always follow your Honda manual and check the ignitor and coil with a DVOM
Yea the only problem with that is it will prob check out cold but I will have to run it again and check it at the track to see what it reads when its not starting. I will prob check it today just to see what it says cold.
