Central Florida Turbo bound from Texas<
Well guys I have been building this car for almost two years now... i will add more pics.... but the time has come for a tune now.... I have been talking to the guys at CFT and should start making the trip tomorrow towards florida to get tuned fridea. 886 miles one way about 13 hour drive. The tuner recomended type r cams but they will be hard to find by friday but if i do find some at affordable price i will buy them. but for now here is the set up... Enjoy... (i know its not the cleanest setup but i built everything in the kit)
Motor setup
block consist of:
83mm golden eagle block
83mm cp pistons 9:1
Eagle 900hp rods
New oil and water pump (oem)
arp head studs
acl bearings
Head consist of:
b16 head
gsr cams(unless can find some type r cams)
Supertech valvetrain
stock valves
Edelbrock intake manifold
Turbo set up :
Homemade ramhorn
T3 60-1 stage 5 wheel .82ar
2.5 inch ic piping with 600hp intercooler
tial 41mm wg and dumptube
Vortech bov ( i have a tial 50mm just have to weld it on will do this after tune)
3 inch exhaust and dp
Fuel:
1000cc msd injectors
aem fuel rail
walbro 255hp
-6 line conversion from firewall to rail (inline filter)
suspension:
ksport coil overs 36 way adjustable and all new supsension components( ball joints tie rods etc.)
Im hoping to make about 430 to 450 on pump gas ang 550 plus whp on race gas... Im hoping this can be had with the gsr cams b/c its not looking good on finding the type r cams before friday ....
here are some pictures ... sorry for crappy cell phone pictures
these are some older ones windshield has been fixed
wastegate and what not was not finished in this picture
i know i know i have some wires to clean up...loll as well as the rest of the engine bay....
Motor setup
block consist of:
83mm cp pistons 9:1
Eagle 900hp rods
arp head studs
acl bearings
Head consist of:
b16 head
stock valves
Turbo set up :
Homemade ramhorn
Fuel:
aem fuel rail
walbro 255hp
suspension:
Re: Central Florida Turbo bound from Texas<
its about a 7 hour extra drive.... And i just want these guys to tune my car.... I know Tony is bad *** at what he does but These guys are the ones that are gonna tune my car.... I will end up spending the same and or less money going to Florida and i get a mini vactation out of it
I can't tell which pic is first or last but I hope you didn't leave the braided oil feed line behind the timing belt... that's a snapped belt waiting to happen.
Good luck!
P.S. You're nuts for driving that far away from one of the best tuners in the country much less your own state.
Good luck!
yes the oil line has been moved lol..... and cft is good at what they do also.... i couldnt afford tony im short by at least 400 dollars for tony to tune its cheaper for me to go to cft and i really like their work not that i dont like tonys.... he gave a friend of mine two flawless tunes
you cant afford tony to tune your car, but your gonna spend all that money on gas to drive to florida? there isnt anything wrong with cft, but t1 is just way closer.
its all about the quality you can afford, so it shouldnt matter,..dont think tony is down for cash plus monopoly money to fill the deficit void.
I have exactly enough money to go to florida have them tune car and come back.... im short about two hundred dollars for tony .... i know its only a couple hundred dollars but i just dont have it nor can i spend any more money on this project... having two kids and being a single parent i just cant do it... and the price of cfts tune is what makes it possible for me to get tuned by them and be able to drive their also. It is what it is nothing i can do about it.... Both shops are bad ****
Damn, and I used to think driving 5 hours to the dyno was alot (that was the only option).
So since you only have exactly enough for the minimum, what is your plan if things go wrong?? What if you need to buy parts while your there?? Or you break and have to drive all the way back with nothing (or tow vehicle breaks down)?? I would never go to the dyno without at least a few hundred extra for parts/problems, let alone driving 13 hours or whatever.
Good luck, it just does not seem like a good plan on a short budget.
{ appreciate the guys at cft and how they were gonna help me out but agter thinking about it.... it would be nice to have local support if i ever neet to change anything..... that way im not stuck going to florida for retune and what not just go see tony
DixielandImports Please
If I could save a little extra money I would drive to T1.
Or hell even miller.
I was gonna go to CFT, but orlando just isnt a great place to have a nice car around.
