tranny/gear set?
Old Nov 16, 2009 | 08:20 PM
runsfromdacops's Avatar
Default tranny/gear set?
Car: full int. dc-2
Power: track: 750ish
Street:600ish
Tires: track:25"x9
Street: some 70/215/15 cheaters
Curennt tranny: stock gsr with a lsd
This is my summer street beater/weekend track ****. So. I need a gear set that I can drive on the steet and will take some vary hard days at the drag strip with out needing a rebuild every 2 weeks. What do you guys suggest
-alex
Old Nov 17, 2009 | 01:01 PM
Default Re: tranny/gear set?
Come on I know some one in here makes big dog pwoer and has a streetable tranny.
Old Nov 17, 2009 | 01:28 PM
NonovUrbizniz's Avatar
Loved
Mfactory, Liberty, there are a bunch of aftermarket gear suppliers.
You might be better off posting in transmission section. or searching... I'm sure this has been covered numerous times.
Old Nov 17, 2009 | 08:22 PM
Ht search sucks ***.
Liberty only makes a bog dox as does ppg
So is mfactory the only one that makes a streetable gear set?
Old Nov 17, 2009 | 08:23 PM
Old Nov 17, 2009 | 08:24 PM
redboost10's Avatar
liberty has a face plating process that you might be interested in.
Old Nov 17, 2009 | 08:25 PM
TheShodan's Avatar
Moderator
What "gearing" do you want? It's not just plug and play. Each combination has its own uses designed for drag strip and street use. Hate to say it, but since you haven't stated real goal or researched gear ratios themselves, you'd be surprised on how well the stock one works.
Old Nov 18, 2009 | 06:42 PM
i have looked at the ratios and im sooooo lost. i think i need some thing close to a gsr maybe with a longer 5th. the car is mostly for the street but even on 600whp on the street stock trannys blow up all the time.and i want the tranny to stand up to so mid 10s at the track and still get me home
as for the liberty face plating i think that is for the dog box only
thnaks for the input. keep it coming
-alex
Old Nov 18, 2009 | 06:58 PM
redboost10's Avatar
-alex
i believe they have a faceplating "process" for the stock gears. so basically you have a helical cut dog box with stock gears.
there is a thread around here where there are plenty of pictures of this.
Old Nov 18, 2009 | 07:15 PM
TheShodan's Avatar
Moderator
Don't know how you're blowing them up. that is interesting. But you're close to needed a good dog box anyway. most "mid 10s" believe it or not use stock gears.
Old Nov 18, 2009 | 08:11 PM
there are alot of guys in my area that have mid to low 10s cars they drive on the street and most end up buying 4-5 trannys/gears a summer. i would rather spend some $$$ this winter then spend the summer watching ppl race.i jsut dont want to be thinking all the time if this will be the run that my tranny blows up on.i know there are some ppl that some how get away with running stock tranny and stock axels but most will kill stock tranny after stock tranny.most of the time the teeth shear right of the gear.i know some ppl around hear have tried cryoed/heat treted gears but no luck.
i dont think face plating will help as it not the seyncro failing its the gear its self.
Old Nov 18, 2009 | 08:24 PM
MFactory's Avatar
Faceplating is the process of turning the stock gear's synchro engagement into dog engagement. The customer wants a street car (i.e retain synchro engagement), so this is not what he requires. If, however, he wants dog engagement on a budget (< $1k I believe?), then this could be a good option.
Old Nov 19, 2009 | 03:48 PM
thanks for the info on the face plating.
mfactory must have some thing for me right?i just want a tranny i can beat on the street with out it blowing up all the time
-alex
Old Nov 19, 2009 | 10:08 PM
MFactory's Avatar
We have a synchro gear set suitable for both street and track, yes.
MurkyRiversEK
Transmission & Drivetrain
19
Aug 14, 2012 12:45 PM
audiimportech
Jul 13, 2007 09:13 AM
all-mtr-teg
101
Jun 7, 2007 09:42 PM
jdmhondageek
22
May 3, 2003 07:34 PM
