finally returbo'd need CEL help
Old Jul 24, 2001 | 02:05 PM
4dGSR at work's Avatar
Default finally returbo'd need CEL help
ok i am driving at like usual w/ obd2.6523875682145617 i get a stupid CEL.
CODE 67 i beleive that is tripped from the second O2 sensor
the car goes in limp mode but the timing doesnt change....not sure if vtec still hits. Would a better O2 sensor stop this(bosch??)???
anyone got any tricks? Till then all i got is to reset the ecu(battery method).
Old Jul 24, 2001 | 02:56 PM
G's Avatar
G
Default Re: finally returbo'd need CEL help (4dGSR at work)
If it is due to a missing cat and it is an o2 sensor code, I have a solution. If it is with a cat, then I guess it is the o2 sensor. I believe the secondary o2 sensor is a little slower than the primary in response, so you should stick with the same one for the secondary......
Old Jul 24, 2001 | 04:29 PM
sgT's Avatar
sgT
Default Re: finally returbo'd need CEL help (G)
There isnt a limp mode for that code.
Old Jul 24, 2001 | 05:29 PM
yellowbulbs's Avatar
New User
g: what is ur solution
i'm running a test pipe and i'm bound to get it one day
Old Jul 25, 2001 | 05:55 AM
bigTom's Avatar
Default Re: finally returbo'd need CEL help (yellowbulbs)
i told ya 4dgsr at werk
Old Jul 25, 2001 | 10:38 AM
gns30's Avatar
New User
Default Re: finally returbo'd need CEL help (ek9t)
Here give this a try, it worked on my accord.
http://www.eaton-design.com/mustang/mil/
Old Jul 26, 2001 | 01:57 PM
Default Re: finally returbo'd need CEL help (gns30)
any other ideas and the car studders at 4500
vtec zone the bitch is flooding i believe...any ideas?
would the v-afc do it? it is obd2,769587682756392876382763876
Civic98KH
15
Dec 10, 2012 08:26 PM
xKAMILxEK
11
Apr 15, 2010 08:52 AM
98savage
May 15, 2007 10:33 PM
