OBD wiring problems
Old Jul 28, 2001 | 05:07 PM
SCsol's Avatar
Default OBD wiring problems
hey there guys im changing my motor i have a 93 delsol with obd1 ECU and harness under the hood, will a OBD2 Gsr motor plug in and work with my OBD1 wiring harness thats under the hood thanks for your help
Old Jul 28, 2001 | 05:52 PM
b18bturbo's Avatar
Default Re: OBD wiring problems (lowsol)
yes all you do is use the obd1 harness and get an obd1 distrib
Old Jul 28, 2001 | 09:20 PM
Hondata's Avatar
You do not say what engine is on the Del Sol. If it is the 1600 sohc Vtec then the engine computer you have, remapped with a Hondata stage 2 system to GSR Spec will work the engine very well. You will probably lose a little low end torque.
Check out http://www.hondata.com/civic9295.html and the other Hondata tech pages.
Old Jul 28, 2001 | 09:46 PM
SCsol's Avatar
Default Re: OBD wiring problems (Hondata)
hello there guys what i want to know is can i plug the obd2 wire harness that on the motor into the OBD1 wire harness thats in the engine bay (the plugs are the same) but do the wires go in the same place thanks guys
Old Jul 29, 2001 | 08:02 AM
b18bturbo's Avatar
everything goes in the same place. But you must use your obd1 harness and not your obd II harness.
Old Jul 29, 2001 | 11:56 AM
VaporTrail's Avatar
New User
use your obd1 wiring harness.
lejeaune
Apr 21, 2010 09:31 AM
advan414
Feb 25, 2008 02:28 PM
1BADEGDC2
May 12, 2007 07:43 PM
danxdan
Jul 13, 2005 03:37 PM
SCsol
Jul 29, 2001 09:52 PM
