dyno results.
Old Jul 26, 2001 | 07:57 PM
quikrpm'z's Avatar
Default dyno results.
wish I had a scanner, heres the numbers.
air temp=92.5 deg F, max hp=184 max tq=165, 7psi
RPM ---- Power ---- Torque ---- Air/fuel
2500----- 36.3 ---- 76.2 ---- 14.6
2600----- 47.8 ---- 96.5 ---- 14.6
2700---- 52.4 ---- 101.8 ---- 13.8
2800---- 56.0 ---- 105.1 ---- 13.6
2900---- 59.7 ---- 108.1 ---- 13.6
3000---- 59.1 ---- 103.5 ---- 13.3
3100---- 66.1 ---- 112.0 ---- 12.2
3200---- 72.5 ---- 118.9 ---- 11.2
3300---- 79.4 ---- 126.3 ---- 10.1
3400 ---- 89.8 ---- 138.7 ---- 10.0
3500 ---- 99.5 ---- 149.4 ---- 10.0
3600 ---- 104.0 ---- 151.7 ---- "
3700 ---- 103.8 ---- 147.3 ---- 10.2
3800 ---- 104.3 ---- 144.1 ---- 10.5
3900---- 106.6---- 143.6 ---- 10.2
4000 ---- 108.5 ---- 142.4 ---- 10.0
4100 ---- 111.8 ---- 143.3 ---- 10.0
4200---- 116.7---- 145.9 ---- "
4300---- 123.4---- 150.8----
4400---- 132.9---- 158.7
4500---- 140.4---- 163.9
4600---- 144.8---- 165.3
4700---- 144.8---- 161.9
4800---- 146.6---- 160.4
4900---- 147.5---- 158.1
5000---- 147.9---- 155.3
(5500-5700)---- 172.5
6200----181.9---- 154.1---- 10.0
Looking at the graph now I see why it felt so bad after 3K.
need input on these numbers, and also what ratio does the fmu come with with the kit? I definately need to do something about the fuel, and need suggestions.
[Modified by quikrpm1, 9:00 PM 7/26/2001]
[Modified by quikrpm1, 9:10 PM 7/26/2001]
Old Jul 26, 2001 | 11:17 PM
Mr. Softee's Avatar
Default Re: dyno results. (quikrpm1)
hey im in az also, ever go to kiwanis? and can you tell me more about your setup (b18b drag im guessing)... i am gonna do same thing
-sam
Old Jul 27, 2001 | 06:23 AM
BigProbe's Avatar
Is that showing a 10:1 A/F ratio???? Shouldnt your motor blow up? I know the DSM guys run around 13.x:1, I am at 12.9:1 but 10??
I'm sorta new here, so what are the major details of the system? If you can get your plot to Kinko's they can scan it, and I'll give you a free place to host the image...
[Modified by BigProbe, 7:24 AM 7/27/2001]
Old Jul 27, 2001 | 07:04 AM
KJ's Avatar
KJ
Default Re: dyno results. (BigProbe)
13:1 is MORE DANGEROUS than 10:1.
He's running extremely rich and needs to lean out the A/F mixture a bit.
Old Jul 27, 2001 | 07:26 AM
BigProbe's Avatar
Default Re: dyno results. (KJ)
<-- foot in mouth
Oh, Duh! yeah, sorry...10:1 = MORE RICH than 13:1 ..sorry, brain fart... so, what I MEANT to say is, if you can perhaps bleed the signal to your FMU, (Grager valve?) you may be able to pick up some power up top.
Old Jul 27, 2001 | 08:29 AM
FAST94GSR's Avatar
New User
lean your car to 12:1 you should pick up about 20hp easy.
Old Jul 27, 2001 | 08:12 PM
quikrpm'z's Avatar
Default Re: dyno results. (FAST94GSR)
lets see setup
97ls engine
drag 3 kit (using everything that came with kit)
7 heat range plugs
WS exhaust, no cat
act clutch
shitty a** tires, stock height
I dont go to Kiwanis, Ive heard a lot of bad stories about there. If you are serious about getting the kit and wanna check out my setup let me know.
So does anyone know what the ratio of the fmu is with the kit? Or can anyone suggest the correct ratio of fmu to use based on the readings. The guy I bought the kit from was running like 9-11 psi, so im thinking he was running with a higher fmu. I dont really have a means of leaning it out, im still using stock regulator and injectors. Any other means of leaning it out? thx for all the replies.
Old Jul 27, 2001 | 08:35 PM
BigProbe's Avatar
Go to an aquarium shop, and you can get a "granger valve (sp?) which would allow you to bleed some of the boost signal to the fmu. The dyno shop should know to to hook it up...shouldn't me more than aboot $10.
Old Jul 27, 2001 | 08:48 PM
quikrpm'z's Avatar
never heard of that, how reliable or how accurate would that be?
Old Jul 27, 2001 | 10:04 PM
DIRep972's Avatar
Smarter than you
why does it only show RPMs up to 6200, the LS revs to 6800 right?
Old Jul 28, 2001 | 02:17 AM
Ray's Avatar
Ray
New User
Default Re: dyno results. (DIRep972)
Hey but look at those torque numbers
Old Jul 28, 2001 | 09:21 AM
BigProbe's Avatar
Its very accurate, but youd need to tune it on a dyno...I know of a guy w/ a 626 with about 300whp who has been using a sim set up for years. basically, you just open the valve in VERY small incriments, to allow x amount of boost to bleed from the signal line to the fmu. I will dig around, and try to find detailed instructions for ya..
petrv
Nov 4, 2003 12:49 PM
