FUEL INJECTORS
Old Jul 30, 2001 | 02:38 AM
Turbohatch's Avatar
New User
Default FUEL INJECTORS
i was just wondering on what is a good size injector to move up to, i have a b16 with fmax turbo set up. I want to run around 9- 10 pounds. And is it bad to have too big of injectors?????
[Modified by Turbohatch, 11:39 AM 7/30/2001]
Old Jul 30, 2001 | 08:03 AM
TurboInteg95's Avatar
Default Re: FUEL INJECTORS (Turbohatch)
get some 310's
Old Jul 30, 2001 | 08:10 AM
b18bturbo's Avatar
Default Re: FUEL INJECTORS (TurboInteg95)
i would get the 370cc or the 310cc the 370cc will be littler harder to control off the stock ecu but it will run at lower duty cylce. The 310 cc will be pushing the 90% duty cylce plus at 10psi.
Old Jul 30, 2001 | 09:14 AM
Default Re: FUEL INJECTORS (b18bturbo)
He'd have to buy some sort of fuel controller for the 370's.
Old Jul 30, 2001 | 11:53 AM
Turbohatch's Avatar
New User
what are some good fuel controllers????
Old Jul 30, 2001 | 12:24 PM
b18bturbo's Avatar
the VAFC is one of the best for just simple modest fuel controllers its nothing special its totally based on rpm rather than a map signal. The best bet ofcourse is simple hondata solution. the 370cc can be controlled through a VAFC using the negative side works well but nothing too great.
Old Jul 30, 2001 | 01:02 PM
dbman96's Avatar
New User
I keep wondering if there's any way I could hook up an oscillator tapped off the MAP signal into my VAFC to simulate an RPM signal so I could use the RPM-based setup to correct fueling under boost instead.
Old Jul 31, 2001 | 08:55 AM
SiRkid's Avatar
Default Re: FUEL INJECTORS (dbman96)
will a vafc due though? to control 370?
Old Jul 31, 2001 | 09:25 AM
98Psi ITR's Avatar
What would be a good price to sell some 310's for ?
Old Jul 31, 2001 | 09:47 AM
Default Re: FUEL INJECTORS (98Psi ITR)
I bought mine off of someone here for $100. They had bought them from someone here as well for $150. so I guess somewhere around there.
Old Jul 31, 2001 | 11:07 AM
Turbohatch's Avatar
New User
anyone selling 310 injectors ?????? and wheres a good site to buy from cheap
Old Jul 31, 2001 | 11:25 AM
MackSpeed-616's Avatar
i have some RC 370's for sale used about 6months
250shipped
jdm_ef9_b16
Jan 24, 2007 03:27 PM
89 CRX SI
Feb 3, 2004 06:01 PM
EggEX2000
Jun 1, 2003 01:16 PM
Turbohatch
Sep 23, 2001 04:59 AM
