BOOST CONTROLLERS increase HP!
Old Aug 2, 2001 | 05:21 PM
SIK IN DA HED's Avatar
New User
Default BOOST CONTROLLERS increase HP!
i just got my SUPER STREET mag today and i went through the issue just now. they explained turbo tech and did dyno tests on boost controllers.
the boost controllers tested were:
-APEXi AVC-R
-BLITZ Dual SBC I-D
-HKS EVC IV
-GREDDY PROFEC B
the max power tested was on a 240sx with a SR20DET motor. i dont think motors are a great factor here though.
the max power was 183.2 at 12.5 lbs of boost
the results were: (with the boost controller)
-APEXi AVC-R 209.6@6,100rom
-BLITZ DUAL SBC 214.1@6,200rpm
-GREDDY PROFEC B 209.1@6,3000rpm
-HKS EVC IV 212.4@6,000rpm
this is very interesting.
Old Aug 2, 2001 | 08:16 PM
SpoonCivic's Avatar
New User
Default Re: BOOST CONTROLLERS increase HP! (dlplayboy)
Its cuz the SBC-id has an auto and manual mode so u can do all these sorts of adjustments I have yet to figure out..its pretty weird though..cuz if they r all banging out the same boost then they should hit down the same amount of hp theoretically..
Old Aug 3, 2001 | 12:11 AM
New User
Default Re: BOOST CONTROLLERS increase HP! (SpoonCivic)
what type of adjustments?
Old Aug 3, 2001 | 06:17 AM
BigProbe's Avatar
those seem like crappy numbers to me, for 12.5psi...:???: Am I reading this correctly to say that w/ NO boost controller the hp was 183, and by adding a boost controller (at the same psi?) the hp rose by 20hp? That couldnt happen. regardless, a dif off 5hp on a turbo'd car is nothing. they could be up or down 5hp between runs from a variety of reasons.
Old Aug 3, 2001 | 11:18 AM
New User
Default Re: BOOST CONTROLLERS increase HP! (BigProbe)
well... if you got a problem with the #'s, go talk to SUPER STREET about it. they have the dyno charts to prove it in the magazine.
Old Aug 3, 2001 | 11:23 AM
Ricehornet's Avatar
I agree the 5+/- can happen for any reason, a gust of cold or hot air, someone exhaled releasing hot air into the intake tract.
but the 20 hp from the boost controller, interesting.
Old Aug 3, 2001 | 11:25 AM
VaporTrail's Avatar
New User
Default Re: BOOST CONTROLLERS increase HP! (Ricehornet)
hmmm this is interesting. That's a lot of power for not raising the boost pressure at all
Old Aug 3, 2001 | 01:26 PM
Smilez's Avatar
New User
Could the HP actually come from different tollerances in the boost controller? IE the SBC is allowing more boost through then profec b?
Old Aug 3, 2001 | 01:38 PM
GSRwBOOST's Avatar
Default Re: BOOST CONTROLLERS increase HP! (Smilez)
My guess is that the BC can hold the boost pressure more consistantly and doesn't modulate up and down as much, bleeding and regulating as the other ones??
Old Aug 3, 2001 | 07:31 PM
New User
Default Re: BOOST CONTROLLERS increase HP! (GSRwBOOST)
i figured that the boost controller is alot more consistent in holding in the boost pressure desired before slowing down the spooling of anymore boost... then releases it full blast! cool... doesnt make hp... just holds boost together better i guess.
Old Aug 3, 2001 | 09:29 PM
Ray's Avatar
Ray
New User
If the boost controller makes a difference in hp what about wastegates? Like a electronic boost controller with delta vs. Tial wastegates
Old Aug 4, 2001 | 02:12 AM
New User
Default Re: BOOST CONTROLLERS increase HP! (Ray)
interesting thought, ray...
Old Aug 4, 2001 | 01:42 PM
turbogsr's Avatar
I don't have the magazine in front of me right now, but if I remember, the base run w/out the boost controllers was at less psi than the runs made w/ a boost controller. Check it out and you'll see. I have the SBC-id and I'm sure it didn't give me horsepower. Its a very powerful boost controller though. I have a 9 pound spring in my wastegate and when I set the boost controller to 0, I boost 6lbs. Thats actually less than my spring. Thats not supposed to happen. So I found that pretty cool.
Old Aug 4, 2001 | 02:05 PM
Ricehornet's Avatar
Default Re: BOOST CONTROLLERS increase HP! (turbogsr)
less than the spring eh, how does that happen?
Old Aug 5, 2001 | 12:28 AM
DIRep972's Avatar
Smarter than you
dont some of these BC's use fuzzy logic where they try to remember the boost curve for maximum boost pressure regulation?
Old Aug 5, 2001 | 02:00 AM
Big James's Avatar
New User
Default Re: BOOST CONTROLLERS increase HP! (DIRep972)
Yes, the HKS does. I know the Greddy Profec A does, not sure about the b. I am not sure about the other 2.
[Modified by Big James, 7:20 AM 8/5/2001]
Mugencrxsir1
Mar 26, 2006 02:31 PM
underpressure02
Oct 29, 2003 09:14 AM
BeerMoon
Jul 6, 2002 07:21 AM
DIRep972
Aug 5, 2001 07:51 PM
