to blockguard or not to blockguard...
Old Jul 24, 2001 | 11:46 AM
bruthaboost's Avatar
Default to blockguard or not to blockguard...
Okay, I read many posts on this subject, however can anyone recommend or oppose any blockguards (brands as well) from personal experience.
many thanks
Old Jul 24, 2001 | 11:50 AM
LsTurbo91's Avatar
Default Re: to blockguard or not to blockguard... (b18bpwr)
I have a race engineering blockguard on my LS, no cooling problems.
Old Jul 24, 2001 | 11:58 AM
b18bturbo's Avatar
Default Re: to blockguard or not to blockguard... (9psiLsT)
the raceeng.com ones are nice. They dont have much problems from what i hear.
Old Jul 24, 2001 | 12:02 PM
9psiLsT are you running a stock radiator?
Old Jul 24, 2001 | 02:03 PM
LsTurbo91's Avatar
yes stock cooling except for a 160 degree thermostat.
Old Jul 24, 2001 | 02:05 PM
VaporTrail's Avatar
New User
really? I've seen 2 of 5 I've used crack (the guards and the block) - both were on LS's.
Old Jul 24, 2001 | 02:17 PM
LsTurbo91's Avatar
Default Re: to blockguard or not to blockguard... (VaporTrail)
yup. The only cooling problem I've had was when I switch my stock gutted fan to a slim autozone fan. The temp would rise if i was stuck in traffic then if i get moving again it would drop back down. So for now I have to leave it running all the time if its like 100 degrees outside other than that its fine.
Vaportrail: How long after you installed the blockguards on the ls's did it crack, how much were they boostin?
Old Jul 24, 2001 | 03:55 PM
Also what do you think caused the cracking?
Old Jul 25, 2001 | 09:31 AM
Doodoo's Avatar
Well heres my experience:
Got the STR blockguard for my LS. Finally got boosted a couple of weeks ago.
I talked to the guy that helped me install my turbo and he asked me if I put the blockguard in before I machined the cylinder walls....nope. I don't know what cylinders if not all 4 are warped. She smokes like a bitch now...sad sad days until I get it fixed. And its all my fault.
This is my experience with building my motor. Some have never had a problem so weigh your options.
Old Jul 25, 2001 | 11:18 AM
bigTom's Avatar
Default Re: to blockguard or not to blockguard... (Doodoo)
i have heard of numerous blocks getting warped from the str blockguard... imo i wouldnt trust it...
Old Jul 25, 2001 | 11:27 AM
Default Re: to blockguard or not to blockguard... (ek9t)
Thanks for the experiences and advice y'all. I'll stay away from them and on the conservative side of boost
Old Jul 25, 2001 | 11:46 AM
D-SPEED's Avatar
at what psi level is a block-gaurd recommended ?
Ej1SIR
Apr 14, 2010 05:02 AM
chrisfromsrq
Feb 10, 2010 01:06 PM
robbys89
Apr 26, 2009 06:26 AM
eglslsd
Jan 22, 2008 09:01 AM
a1320addict
Aug 17, 2005 08:12 PM
