when installing new pistons/rods do they need to be balanced?
Old Aug 2, 2001 | 06:38 PM
lucas569's Avatar
Default when installing new pistons/rods do they need to be balanced?
i'm asking because i'm planning a rebuild w/ je pistons and crower rods but was wondering if the tolerances were very close...
Old Aug 2, 2001 | 08:54 PM
VaporTrail's Avatar
New User
Default Re: when installing new pistons/rods do they need to be balanced? (lucas569)
Crowers come balanced already. Not sure about the JE's...
Old Aug 3, 2001 | 09:59 AM
lucas569's Avatar
Default Re: when installing new pistons/rods do they need to be balanced? (VaporTrail)
thanks vaportrail,well after making some phone calls and seeing what a dent all the materials are going to cost ive deciced to go w/ EAGLE rods instead. not a bad compromise.
my concern is the balancing of these components,has anyone in here dropped some rods/pistons in w/ out having them balanced?
im basicaly doing a standard rebuilt w/ aftermarket rods and pistons,and MAYBE (BIG maybe) sending the head off to portflow (depending on if i get my raise)
the setup will be:
95 GSR motor
DRAG 3 kit w/ Tial wg
JE pistons-EAGLE rods
portflow head w/ titanium valve srings
440 cc RC injectors
Hondata stage 3b
Bosch fp
Greddy ebc
Greddy tt
Greddy A/F gauge
CM stage 3 w/ JUN 10lb fw
i'm trying to make it as reliable as possible,thats my main goal.(10-12 psi reliably) i'm tearing down the engine soon anyhow thats why im going w/ the upgraded internals...
[Modified by lucas569, 11:02 AM 8/3/2001]
Old Aug 3, 2001 | 11:21 AM
VaporTrail's Avatar
New User
sounds like a good setup. If you can't afford the head work, try a skunk2 intake manifold on there, it makes good power!
Old Aug 3, 2001 | 12:49 PM
lucas569's Avatar
you know i like the gains ive seen w/ the skunk manifold but the drag piping i bought is for a gsr. id like to redo the head anyhow (just a matter of time and money) cause the motor has about 100k miles.
Old Aug 3, 2001 | 01:45 PM
optiontoo's Avatar
New User
Aftermarket parts are supposed to be balanced, but there is a small error and when you combine it with the bearing, rod/piston, wristpin and ring pack you can get a setup that's more than 1.0 grams off of one another.
I picked up an analytical scale and a rod balancer (looks like a seesaw), about $400 for the pair, probably well worth it because getting a shop to balance your parts is $$$$. Though you'll still need to have a shop balance the crank.
Vagitarian
Sep 14, 2012 02:14 PM
Townson
Jan 7, 2009 08:43 PM
PnkRokCountryboy
17
Nov 20, 2005 04:08 PM
jsimon9633
Oct 2, 2004 11:29 AM
No-Gi
Sep 2, 2002 09:01 AM
