fuel options for turbo setup
Old Jul 24, 2001 | 07:02 PM
D-SPEED's Avatar
Default fuel options for turbo setup
the standard ( cheap ?) setup for turbos seems to be the boost dependent FPR, bigger fuel pump etc....what comes with the drag and rh kits.
what are other options for the fuel system ?
-stand-alone just uses new fuel maps and bigger injectors right ?
if you are running in the area of 8psi, could you use something like 310cc injectors with a bigger fuel pump and then use a VAFC to dial it in ? this seems like it would be the most simple solution to fuel in a turbo setup....
does this work or not ?
Old Jul 24, 2001 | 07:26 PM
Rob03Pro5's Avatar
Default Re: fuel options for turbo setup (D-SPEED)
Extra injectors along with an extra injector controller (EIC or AIC) is another option. I believe F-MAX kits come with two extra injectors that are mounted on the IC piping before the T-body.. controlled by an AIC. My personal setup (future turbo setup) will have a custom fuel rail with 4 additional injectors.. along with the SDS EIC.. better fuel distribution to all cylinders.
Old Jul 24, 2001 | 07:27 PM
92CivicSiR's Avatar
New User
Yes, if you are only running 8psi those injectors would work just fine. You could even get a fuel computer and some secondary injectors. That is the way im going to do my turbo setup. I'm going to use the stock injectors with two 440cc seconday injectors mounted in the charge pipe.
Old Jul 24, 2001 | 08:17 PM
TurboInteg95's Avatar
the VAFC cannot compensate for boost. It is RPM based making it nearly useless on turbo cars other then fine tuning.
Old Jul 24, 2001 | 09:23 PM
TheShad0w's Avatar
Default Re: fuel options for turbo setup (TurboInteg95)
Damn guys im not sure im fallowing ya on this, kinda used to good old NA, running circles around me
Old Jul 24, 2001 | 09:30 PM
VaporTrail's Avatar
New User
Default Re: fuel options for turbo setup (TheShad0w)
http://www.hondata.com
Old Jul 27, 2001 | 06:16 PM
SIK IN DA HED's Avatar
New User
Default Re: fuel options for turbo setup (VaporTrail)
wouldnt using 310 injectors and an inline fuel pump (drag3 kit) and a stock fuel pump with a 12:1 fmu ratio make it even more richer than it is with stock injectors instead?
what is the better combo to make more power? cuz i heard if u run rich... u lose HP potential.
bosted429whp
May 21, 2016 04:22 PM
golf-mk3
Oct 7, 2010 05:27 AM
boostfed-wwjd
Apr 23, 2007 06:36 AM
NXAccordTO4B
Nov 18, 2003 07:30 PM
