JR/Walbro pump question..
Old Jul 22, 2001 | 10:35 PM
leechungsr's Avatar
Default JR/Walbro pump question..
Someone told me that his pump doesn't sound consistant and will change in how it sounds, and it seems like it doesn't pump fuel smoothly. Is this normal, and true?
Old Jul 22, 2001 | 11:01 PM
liam821's Avatar
25 Year Member
Default Re: JR/Walbro pump question.. (LeeChun GSR)
I have a Walbro intank pump. It does make alot of wierd noises...and the sound does seem to change. But the fuel pressure never changes. Well...when i am getting low on gas the fuel pressure starts to jump around alot..but thats when i am about to run outa gas.
But no..the fuel pressure is always the same all the time...it just sounds wierd.
liam
Old Jul 22, 2001 | 11:31 PM
chri5's Avatar
Default Re: JR/Walbro pump question.. (liam821)
when you first put it in you'll think there is something wrong with your engine bacuase of the high pitched noise it makes at idle. The best thing i have found to get rid of the anoyance is to turn the music up The fuel pressure is consistent.
When you say "someone" I am not sure if you mean me or not. If it is me you are reffering to what i was trying to say was that it would be in your best interest to get the Walbro gss342, not the Walbro gss317(which is what Jackson sells). the 342 handles the high fuel pressures much better than the 317. The 317 has been known to go bad at 8 psi because of the high fuel pressures.
If you weren't talking about me I still recommend the 342.
Old Jul 22, 2001 | 11:34 PM
leechungsr's Avatar
Default Re: JR/Walbro pump question.. (Strng1dah)
naw, "CCB" told me that..I don't know if he's on this forum. I might be buying his fuel pump then..
jlong17crx
Dec 20, 2007 09:08 AM
garyc17
12
Apr 26, 2007 05:13 AM
b16hatche
Nov 11, 2005 06:28 PM
Rex_Ryder
Jan 14, 2005 10:32 AM
Andrew 825SM
Nov 17, 2002 01:42 AM
