Exhaust temp gauge?
Old Jul 28, 2001 | 11:16 PM
Pro-Lude's Avatar
Default Exhaust temp gauge?
I was wondering what the gauge should run at. Before my rebuild it was running around 600, just driving normal on the interstate around 65-70mph now it runs 700? Just wondering if thats ok TIA
[Modified by Pro-Lude, 12:17 AM 7/29/2001]
Old Jul 29, 2001 | 08:01 AM
b18bturbo's Avatar
Default Re: Exhaust temp gauge? (Pro-Lude)
that is fine just dont go above 850 running on the highway for constant amount of time.
Old Jul 29, 2001 | 08:19 AM
bigTom's Avatar
Default Re: Exhaust temp gauge? (b18bturbo)
ill second that... if i were u id even try to stay under 800 just to be safe... but 850 for a short amount of time is fine
Old Jul 29, 2001 | 01:07 PM
98lude's Avatar
Default Re: Exhaust temp gauge? (ek9t)
wierd!!! while crusing at 70mph, my egt is like 800C. my probe is 1.5" away on the 3rd cylinder.... what gives???
also, i noticed that mine egt is proportionate to my speed. i checked the readings on dyno, and noticed that for 12.5 a/f ratio, the egt is about 750C...
Old Jul 30, 2001 | 03:55 PM
yellowbulbs's Avatar
New User
this is in celsius right?
mine is around 1200 F at 70 mph
Old Jul 31, 2001 | 04:10 AM
DirtyLude's Avatar
If your EGT probes aren't mounted in the same place, you're all comparing apples to oranges. Before and after the turbo makes a big difference. The turbo itself is a big heat sink.
Project X
Nov 8, 2007 10:32 AM
Luchini
Oct 11, 2005 06:02 PM
Yambor
Mar 5, 2004 08:24 AM
11secdx
May 21, 2003 08:41 AM
degradated
Nov 6, 2001 11:57 AM
