Relieving fuel pressure?
Old Jul 31, 2001 | 09:02 AM
boost killz's Avatar
New User
Default Relieving fuel pressure?
Would you remove the fuel pump fuse or FI fuse under the hood and stall out the car. thanks people,
Nick
Old Jul 31, 2001 | 09:23 AM
LsTurbo91's Avatar
Default Re: Relieving fuel pressure? (boost killz)
I believe there is a service bolt above the fuel filter. I just remove the gas cap.
Old Jul 31, 2001 | 09:32 AM
New User
Default Re: Relieving fuel pressure? (9psiLsT)
Cool deal thanks man, I figured you just needed to stall out the car before removing the service bolt.. Thanks again.
Old Jul 31, 2001 | 09:48 AM
Ricehornet's Avatar
the bolt on top of the fuel filter will leak the gas pressure, and they reccoment you opening your gas cap.
Old Jul 31, 2001 | 10:05 AM
LEON's Avatar
Make sure you put down plenty of towels as you will leak some fuel from the filter and fuel lines even after taking off the gas cap and slowly loosening the fuel filter bolt.
Old Jul 31, 2001 | 11:32 AM
paulzy's Avatar
Default Re: Relieving fuel pressure? (LEON)
take off the gas cap, take out the acg fuse under your dash(it says ACG) it's a 15 amp fuse. crank the motor a couple of times and you're set.
EG-SIXV-TEC
Dec 24, 2009 01:15 PM
oldberkeley
Aug 23, 2005 07:14 AM
Ragezero76
Jul 19, 2004 08:44 PM
andrewasf77
Dec 6, 2002 10:30 PM
HiRevn
May 18, 2002 06:50 AM
