difference between p72 ecu (Doug?)
Old Jul 26, 2001 | 03:02 PM
98lude's Avatar
Default difference between p72 ecu (Doug?)
does anyone know the difference between 37820 P72 A01 and 37820 P72 A02? will both work for Hondata? will getting a 96 integra ecu with obd2 work? i heard that the 96 integra ecu is not a full obd2, or something like that.. is that true?
TIA
Old Jul 26, 2001 | 03:14 PM
redline's Avatar
Default Re: difference between p72 ecu (98lude)
96+ is OBDII where or not Honda fully complied with standards is another thing. The processor is what counts and that is the wrong one (in the 96).
k
Old Jul 26, 2001 | 04:41 PM
98lude's Avatar
Default Re: difference between p72 ecu (redline)
so the a02 is a 96 gsr ecu?
Old Jul 27, 2001 | 04:51 PM
Hondata's Avatar
The P72-A02 I believe is OBD II and is not suitable for extensive reprogramming. Blank chips cost about $200. Every time you want to do a reprogram you throw away the last chip you used.
Old Jul 27, 2001 | 05:01 PM
brian b's Avatar
New User
Default Re: difference between p72 ecu (Hondata)
does that mean you can use an odb2 ecu and just pay the 200 dollars each time you make a change?
Old Jul 28, 2001 | 07:48 AM
Hondata's Avatar
Default Re: difference between p72 ecu (brian b)
The only changes we can make to 96-98 OBD II GSR and Civic ECU at the moment are REV limit VTEC point and NA fuelling and ignition changes. The first ECU reprogram is $400 as we remove and socket a surface mount chip. Subseqent changes are cheaper as we can plug the blank chips into the socket.
dreman24
Aug 10, 2006 10:47 AM
All Day
Mar 8, 2006 06:10 AM
turbo90crx
Mar 28, 2005 05:32 PM
etrnlecho
Sep 10, 2002 10:13 AM
