traction problems... how to control power!
Old Jul 26, 2001 | 01:37 AM
SIK IN DA HED's Avatar
New User
Default traction problems... how to control power!
from mid-high end... i get a surge of power from boost! sometimes... my front wheels shake from traction problems...
would shocks help out with this problem? i also have 17's... it causes wheel hop if i take off too quickly...
any recommendations?
Old Jul 26, 2001 | 06:03 AM
Evil DOHC's Avatar
Default Re: traction problems... how to control power! (dlplayboy)
Nitto 555r, NUFF SAID
EVIL
Old Jul 26, 2001 | 08:50 AM
TurboIntegra's Avatar
Good shocks and motor mount inserts would help a lot. And of course sticky tires always help.
Old Jul 26, 2001 | 09:03 AM
b18bturbo's Avatar
Default Re: traction problems... how to control power! (TurboIntegra)
i would highly reccommend trying a z10eng front traction control system. It works wonders. It cuts 60 ft times down by .3
Old Jul 26, 2001 | 02:22 PM
New User
Default Re: traction problems... how to control power! (b18bturbo)
b18bturbo...
who makes that? what is it? and how much does it cost?
i was thinkin about gettin those kyb adjustable shocks for my car. good idea?
and about those motor mount inserts... is that the same as whut b18bturbo is talkin about? how much do those run and how are they installed? pretty easy?
Old Jul 26, 2001 | 03:25 PM
GSRwBOOST's Avatar
Default Re: traction problems... how to control power! (TurboR616)
I'm assuming you have an LSD?? the drag radials would help a good deal..
what you dont like putting down some tire marks while passing them??
hhahahahah
Old Jul 26, 2001 | 03:32 PM
TheShad0w's Avatar
Default Re: traction problems... how to control power! (GSRwBOOST)
How streetable is that traction bar system, how does it affect your normal control, anyone know?
Old Jul 26, 2001 | 04:37 PM
liam821's Avatar
25 Year Member
[QUOTE]b18bturbo...
QUOTE]
z10 makes them. http://www.z10eng.com
liam
Old Jul 26, 2001 | 08:45 PM
paulzy's Avatar
Default Re: traction problems... how to control power! (liam821)
i would say to balance your wheels first...that might be the problem
Old Jul 26, 2001 | 08:49 PM
VaporTrail's Avatar
New User
here's a review of them on the Honda Hybrid page
http://www.hybrid.honda-perf.org/tech/z10.html
Old Jul 26, 2001 | 10:11 PM
TurboType-R's Avatar
New User
Default Re: traction problems... how to control power! (VaporTrail)
could this help, when your doing an autocross?
Old Jul 27, 2001 | 05:54 AM
E Swift's Avatar
Default Re: traction problems... how to control power! (TurboType-R)
Go buy yourself some LSD!
Old Jul 27, 2001 | 06:04 AM
MiraiZ's Avatar
Default Re: traction problems... how to control power! (420TegLS)
LSD isn't going to help...I have the same problem in first gear...I dump about 3500-4000rpms on my launches (any less and my start sucks) and my front (16 inchers) bounces for a couple of turns. then it really grabs!!
Old Jul 27, 2001 | 06:26 AM
BigProbe's Avatar
I had pretty bad wheel hop until I changed my 70K mile-old Control Arm bushings...did wonders. (shrug)
Old Jul 27, 2001 | 06:30 AM
b18bturbo's Avatar
Default Re: traction problems... how to control power! (BigProbe)
the z10 bar is the only streetable one on the market that i know. It will definitely eliminate wheel hop if preload is set correctly. THe kit goes for around 375 and comes with all hardware. It is powerdcoated red and all hardware is excelent.
Old Jul 27, 2001 | 02:10 PM
New User
so i take it...
control arm bushings, one of those z10eng traction control, motor mount inserts, and some good shocks are good ways of controlling traction? COOL. thanks for the insight, guys....
ls-vtecteg
Sep 3, 2011 06:59 PM
hybridEj6
Jan 16, 2004 12:09 AM
Elite Hatch
Jun 8, 2003 07:11 PM
SIK IN DA HED
Jun 6, 2002 01:03 AM
Ri5e
May 23, 2002 08:33 AM
