Does the external fuel pump create higher fuel pressures?
Old Jul 29, 2001 | 01:49 PM
TurboIntegra's Avatar
Default Does the external fuel pump create higher fuel pressures?
I have the Drag Gen III kit. I have the external Airtex fuel pump that comes with the kit. Will it create higher fuel pressures? Like at idle? Or will the fuel pressures remain the same as stock?
Old Jul 29, 2001 | 02:14 PM
dustin's Avatar
Default Re: Does the external fuel pump create higher fuel pressures? (TurboIntegra)
Fuel pressure is created by restriction in the fuel return line. All inline pumps do is provide the ABILITY to sustain high fuel pressure when something like a Vortech FPR blocks off the fuel return line... and consequently causes more fuel to be injected into the cylinders.
Your idle FP will not change.
Dustin
Old Jul 29, 2001 | 10:49 PM
Hondata's Avatar
Default Re: Does the external fuel pump create higher fuel pressures? (dustin)
Except as the fuel pressure rises less volume of fuel can be delivered by the pump. This gives a fixed maximum horsepower you can generate for any given fuel pressure. See the detailed explanation http://Hondata.com/techfuelpump.html
[Modified by Hondata, 7:50 AM 7/30/2001]
Old Jul 29, 2001 | 11:04 PM
dustin's Avatar
Default Re: Does the external fuel pump create higher fuel pressures? (Hondata)
Yep, pressure is inversely related to flow.
Dustin
iNetForce
Nov 13, 2005 08:27 PM
Dominic-CTR
Oct 24, 2004 04:08 AM
E Swift
Nov 4, 2002 07:55 PM
