where to mount the EGT probe????
Old May 18, 2003 | 05:12 PM
BSTINITR's Avatar
Default where to mount the EGT probe????
i have a greedy egt gauge and i dont know where to mount the probe at ...
Old May 18, 2003 | 05:23 PM
krazyDOHC's Avatar
Default Re: where to mount the EGT probe???? (BSTINITR)
3rd runner on the manifold
Old May 18, 2003 | 05:56 PM
Pritos's Avatar
New User
Default Re: where to mount the EGT probe???? (krazySOHC)
3rd runner.
<insert shameless plug> By the way, this setup is for sale. Anyone, please feel free to check it out!
https://honda-tech.com/zerothread?id=506789
Old May 18, 2003 | 06:01 PM
Jared's Avatar
Default Re: where to mount the EGT probe???? (Pritos)
in the 3rd runner, distance from the head is determined by the size of your primaries. the distance from the head should the half the diameter of your primaries.
Old Jun 2, 2003 | 09:54 AM
hitek_z's Avatar
why the third runner? is this better than where the manual says to put it "tap the thread where the four runners are collected at the base of the manifold" because im tapping mine tonite and would like more info on which is better
Old Jun 2, 2003 | 10:13 AM
BROOD's Avatar
Default Re: (hitek_z)
The third cylinder generally runs leaner than the other cylinders.
Old Jun 2, 2003 | 10:19 AM
KStuned's Avatar
what do you guys think, is an EGT worth having if it is tapped in the downpipe, after the turbo, or should I even use it?
Old Jun 2, 2003 | 10:31 AM
BROOD's Avatar
Default Re: (Hondaddict)
Using the EGT in the DP after the turbo would be better than NOT having it. But you will still get better readings from the #3 runner.
aryiman98civic
Apr 27, 2007 11:21 AM
djnikko
Jul 7, 2004 07:16 AM
TurboB18C1
Apr 15, 2004 03:36 PM
underpressure02
Oct 3, 2003 09:55 AM
civictypenos
Oct 4, 2002 01:55 PM
