blitz bov
Old May 19, 2003 | 04:49 PM
JimmyT89's Avatar
Default blitz bov
whhy doesnt my bov make a sharp sound, it just sounds like air is gettin released but not a nigh pitched one?
Old May 19, 2003 | 05:08 PM
Pritos's Avatar
New User
Default Re: blitz bov (JimmyT89)
what psi are you running and where did you tap for the vac line. dont share that line with alot of other things. find a good dedicated vac line for it.
u may also need to adjust it. I adjusted mine at idle. just let your car idle, put your finger into the bov and feel the piston.. loosen it until the valve is close to being OPEN at idle.
Old May 19, 2003 | 05:10 PM
JimmyT89's Avatar
Default Re: blitz bov (Pritos)
im running at 8 and it has its own vac line to the back on the intake mani. i adjusted it but it doesnt make a difference?
Old May 19, 2003 | 05:11 PM
Pritos's Avatar
New User
is it a used valve? perhaps it needs to be lubed. get some silicone spray on that piston.
Old May 19, 2003 | 05:12 PM
JimmyT89's Avatar
it is a brand new one....what kind of silicone are you talking about. just spray where hte opening is or open it?
Old May 19, 2003 | 05:17 PM
Pritos's Avatar
New User
silicone is so thin that u dont have to open it. just blip the throttle from the engine bay to move the piston around and spray. Although, since the valve is new you shouldnt have to lube it.
why dont you try another vac port. see if it makes a difference.
Old May 19, 2003 | 05:19 PM
JimmyT89's Avatar
well its in new condition, had it in december and then blew the motor, now it is currently up and running again. but i dont recall it sounding correctly the first time. i'll try the lube....so hit hte throttle cable a few times and spray in the silicone?
Old May 19, 2003 | 06:21 PM
Pritos's Avatar
New User
yeah u can feel the piston move and and down when u blip the throttle.. just spray and blip. that is, if its the problem. did u try the other vac source?
Old May 19, 2003 | 06:43 PM
madman604's Avatar
if you are using the blitz DD BOV its not as loud as the older "horn" style, I had both on the same car.
switch over to the horn outlet (yes it fits) and your bov will be ugly but super loud
also take out the filter screen.
Jupe
Honda Civic (2006 - 2015)
Jul 9, 2007 05:04 PM
Jupe
Jul 8, 2007 02:42 PM
eg:R
Sep 17, 2006 06:47 PM
igo4bmx
Jul 23, 2003 09:39 AM
_Endless_
Jul 4, 2003 10:56 AM
