blue box wiring help
Old May 16, 2003 | 03:25 PM
skierGT's Avatar
Default blue box wiring help
ive figured out how to wire all the wires to be spliced into the ecu but i cant understand what to do with the other 2 wires with the male to female conectors. i have the diagram. i just need to know where the wire labeled map goes. i have 3 wores coming out of my map sensor on the intake manifold. is it one of those? and where does the other conector wire go into the ecu?
Old May 16, 2003 | 04:51 PM
BoostedSOHC's Avatar
Default Re: blue box wiring help (skierGT)
is this for obd1? if it is i can tell ya exactly what to do. those wires are to byass the map sensor, what you do is go buy another male and female connector, cut the map sensor wire that goes to the ecu an done end gets the male one gets the female, the instructions show you which, its just running the 2 wires inline so it takes the map sensing into the blue box, then back out to the ecu. the wire colors and which connectors they go to are on the diagram. if you need more specifics i can look at the diagram and tell you. IM me on AIM OR AOL if you want at mack4life8, or PM me hear on H-T.
Old May 16, 2003 | 09:42 PM
skierGT's Avatar
Default Re: blue box wiring help (BoostedSOHC)
thanks dude i understand the concept now. i have the conectors its just that the slot the diagram points to on the chart i dont think has a wire in the ecu harness. ill check it out again tomorrw in the light, but thanks
Robs_B18c
Nov 4, 2009 08:39 AM
Kahuna9889
Apr 5, 2009 05:57 PM
omahaturbocivic
Aug 31, 2003 10:46 AM
This One
Feb 2, 2003 04:20 AM
