good place for oil pan tap?
Just wondering if there is a CERTAIN place where the oil pan tap should be. I am taking my oil pan off to take it and have the screw fitting welded on it and I wanted to know if there is a certain place where it should be. Upgrated turbos and the hole on the oil pan was too small and is spitting out oil under pressure. THANX!!!!!!!!!
Re: good place for oil pan tap? (gsrcivict)
Directly underneath the turbo is the ideal place for it. If you have the turbo on as well as the oil pan, eyeball it and make a mark for the new hole. Also try the search, there are a ton of threads relating to this and some people have even posted pics which should help you out.
Re: good place for oil pan tap? (GudeH23a)
thanx man. I did try the search but Im a computer dummy so I guess maybe I did it wrong. only came out with some people looking to buy a pan. I guess Ill just go press my luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrcivict »</TD></TR><TR><TD CLASS="quote">thanx man. I did try the search but Im a computer dummy so I guess maybe I did it wrong. only came out with some people looking to buy a pan. I guess Ill just go press my luck</TD></TR></TABLE>
check this out
https://honda-tech.com/zerothread?id=268110
check this out
Re: good place for oil pan tap? (metal-x)
thanx! I couldnt get any of theose pics to come up though. I get the idea that as long as the tap is high up on the oilk pan it should be ok. Im just worried about it clearing my downpipe. thanx fellas!!!!!!!!!!!!! Ill be back later to post the results.
i just got done with my install few weeks ago...
here's my post..
https://honda-tech.com/zerothread?id=500962
there's some explicit pics of oil pan / feed / dp and stuff...good luck...
here's my post..
