3bar Map Problems!
Old May 16, 2003 | 12:49 PM
The Crow's Avatar
Default 3bar Map Problems!
I just installed my 3 bar map sensor and drove my car and it ran like crap. I check the volts and I got a 2.2volts. Hondata said I should get a 1.6. Anyone have a clue to why I'm having this problem?
Old May 16, 2003 | 12:54 PM
FIxALPHA's Avatar
Default Re: 3bar Map Problems! (The Crow)
Make sure that your ecu is chiped for a 3 bar map sensor
Old May 16, 2003 | 12:56 PM
The Crow's Avatar
Default Re: 3bar Map Problems! (FIxALPHA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FIxALPHA &raquo;</TD></TR><TR><TD CLASS="quote">Make sure that your ecu is chiped for a 3 bar map sensor</TD></TR></TABLE>
Yes it is.
Old May 16, 2003 | 01:11 PM
racerxadam's Avatar
where did you get your 3 bar map? are you sure it is a 3 bar? you can check to see how high you have to pressurize it to make the voltage output go to 5 volts
Old May 16, 2003 | 01:20 PM
The Crow's Avatar
Default Re: 3bar Map Problems! (racerxadam)
I got it from an AC/Delco parts dealer. I called AC/Delco to double check the part number any they said is was right.
Old May 16, 2003 | 01:47 PM
intekragsr's Avatar
are you using hondata?
Old May 16, 2003 | 02:10 PM
The Crow's Avatar
Default Re: 3bar Map Problems! (intekragsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intekragsr &raquo;</TD></TR><TR><TD CLASS="quote">are you using hondata?</TD></TR></TABLE>
no, but that shouldn't matter
Old May 16, 2003 | 03:17 PM
Spunkster's Avatar
Then what are you using that allows the use of a 3-Bar?
Old May 16, 2003 | 04:23 PM
The Crow's Avatar
Default Re: 3bar Map Problems! (Spunkster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spunkster &raquo;</TD></TR><TR><TD CLASS="quote">Then what are you using that allows the use of a 3-Bar?</TD></TR></TABLE>
I've been sworn to secrecy.
Can someone help me???
Old May 16, 2003 | 04:27 PM
intekragsr's Avatar
how the hell are we supposed to help you when you wont tell me what stand alone you are using? and you are sworn to some secrecy crap.
Old May 16, 2003 | 04:28 PM
GEN2TEG's Avatar
I had a similar problem and it turned out that the clip where the wire is connected was slightly loose.
It may just be that?
Old May 16, 2003 | 04:36 PM
The Crow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intekragsr &raquo;</TD></TR><TR><TD CLASS="quote">how the hell are we supposed to help you when you wont tell me what stand alone you are using? and you are sworn to some secrecy crap. </TD></TR></TABLE>
Can you tell me how the ECU would effect the voltage of the map sensor? Keep in mind the stock stock map has correct voltage.
Old May 16, 2003 | 04:52 PM
ion_four's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Crow &raquo;</TD></TR><TR><TD CLASS="quote">
Can you tell me how the ECU would effect the voltage of the map sensor? Keep in mind the stock stock map has correct voltage.</TD></TR></TABLE>
Look, if the voltage coming out of the MAP sensor is 2.2 when it should be 1.6 it's obvious the sensor is the problem. Either the wiring is jacked up (5v source, not 12v, right?) or your sensor is busted or the wrong one. If you can't share your big-*** secret then I doubt anyone can help any further.
Old May 16, 2003 | 05:28 PM
The Crow's Avatar
Default Re: 3bar Map Problems! (ion_four)
Just check the wiring and it's fine and I just tried a GN map and it reads 2.3volts. It's great to have friends with nice cars.
I need my 18psi!
champLSinteg
Jul 19, 2008 11:21 PM
Kid_SiR
Dec 28, 2007 03:07 AM
BigMoneyP
Sep 9, 2005 02:22 PM
redboost10
Apr 5, 2004 03:56 PM
CiViC SiR
Jul 9, 2003 09:35 AM
