Purpose of Timing being retarded??
Old May 19, 2003 | 06:41 PM
wzcb08's Avatar
Default Purpose of Timing being retarded??
Just wanted to know what purpose this serves. I mean if the car is tuned and it runs good why would you even need to retard the timing under boost? I have been running my setup for about a year and have had no detonation problems and my timing is set to stock. Any answers or opinions would be great.
Old May 19, 2003 | 07:32 PM
T3T495GSR's Avatar
Default Re: Purpose of Timing being retarded?? (wzcb08)
you pretty much just answered your own question but retarding timing is to avoid detonation
Old May 19, 2003 | 07:47 PM
JRSCCivic98's Avatar
Default Re: Purpose of Timing being retarded?? (T3T495GSR)
Some engines can run stock timing and still not detonate under boost. I belive that if your setup is properly intercooled and you run proper octane fuel and proper heat range plugs you may not have to retard timing at all. It all depends on the engine really. Some you can get away with it, others you can't. Generally FI that's not intercooled is where you want to implement retarded timing....... generally.
93lsv_turbo
Apr 15, 2011 12:08 PM
spoolingb20
Apr 26, 2006 10:46 AM
wrXtian
Mar 25, 2003 03:55 PM
DLB1994
Aug 27, 2002 12:10 AM
