Should be running in no time. :P Pics of Engine dropped, Turbo Mounted
New User
Re: Should be running in no time. :P Pics of Engine dropped, Turbo Mounted (2000Accord5sp)
hahahah the mandatory "standing in empty engine bay" pic.
good luck with the setup!
Modified by Pritos at 6:19 PM 5/17/2003
Re: Should be running in no time. :P Pics of Engine dropped, Turbo Mounted (teamlegacy)
i wanna do the same thing but with ac. let me know how it handles.
Re: Should be running in no time. :P Pics of Engine dropped, Turbo Mounted (DubyaAye)
My jaw honestly dropped once I scrolled to the third pic, that is such a hot looking setup.
crap, talk about a jump in power!
Is the motor fully built, how much boost you planning on running?
Re: (lazerus)
White boy? Too bad I'm not white. hahaha
The setup is too long to list but everything has pretty much been replaced. I'm using a '00 h22 engine out of a wrecked prelude.
We plan to boost around 25psi so you can figure out the hp numbers based on that I'm sure.
As far as AC goes, it's a tight fit but we should be able to keep it. (i'm hoping at least. I like cool air inside )
Re: (2000Accord5sp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000Accord5sp »</TD></TR><TR><TD CLASS="quote">
As far as AC goes, it's a tight fit but we should be able to keep it. (i'm hoping at least. I like cool air inside )</TD></TR></TABLE>
hey if you're still going to run A/C are you just putting one fan? would that be sufficient enough?
Re: (accordfreak)
I actually bought two fans with the radiator but they're so big they both don't fit (without some modification). So i think we might try just one and see how it works...since I AM keeping my AC
Engine has been fully built:
GE sleeves (o-ringed)
JE 9:1 pistons
Crower Rods
Crower cams and valve springs
Blue printed and ballanced
Quaife LSD
ACT clutch
Turbo setup:
t3/t4oe turbo
SFP manifold
720cc injectors
autronic standalone
fuel pump, fpr...etc upgraded
Tial BOV
Tial WG
JE 9:1 pistons
Crower Rods
Quaife LSD
ACT clutch
Turbo setup:
t3/t4oe turbo
SFP manifold
720cc injectors
autronic standalone
Tial BOV
Tial WG
EgSalad
03-04-2006 10:10 AM
