it's alive again!!!
Old May 18, 2003 | 10:49 AM
scttydb411's Avatar
Default it's alive again!!!
finally got the car restarted. 1 tsp of oil down each sparkplug hole and let it sit for an hour. first try it started right up. wahoooo!!! took it for a test drive and boost to 6-7 psi. doesn't spool quite as quick as it did without the downpipe, but it's very quiet now and i'm not boiling the clutch fluid. i drained my oil since i washed my cylinders so much with fuel.
you don't think i could've done much damage trying to crank it ten or so times flooded so badly as i was? car seems to boost fine and i'm no spewing oil or anything out of the tailpipe.
i'm running 1/4inch id fuel hose for my oil lines. i know they can handle the psi, but what about the temp of the oil running through them? they seem to get pretty hot.
after test driving i have my settings on my safc reset to 98lo99hi and -38 correction from 1k-4k, -37 4.5k, -36 up on both lo and hi. car seems to run like a champ. it tended to stall when i came to a stop at -40. i also have my btm at .5/1psi.
thanks to everyone that posted helping me to get the car restarted.
flash69
May 7, 2009 02:49 PM
YoungKadafi
Jun 11, 2006 01:52 PM
Tad
Feb 13, 2004 08:22 PM
SupaTegRS
Apr 14, 2003 11:02 PM
DaeDae12
Nov 3, 2001 07:10 AM
