h22a turbo question
Old May 16, 2003 | 01:29 PM
BUCKO5's Avatar
Default h22a turbo question
i know that a stock prelude block can only take about 5 psi, because of the aluminum sleeves, but if i just sleeve it, and balance the stock rotating assembly, what kind of psi can i put on the otherwise stock motor?
Old May 16, 2003 | 01:31 PM
BoostedH23a1's Avatar
Default Re: h22a turbo question (BUCKO5)
no man.. its the ringlands on the pistons..
if u resleeve at least get some pistons and eagle rods.. i would run AEBS sleeves, je pistons, and crower rods if i were u..
Old May 16, 2003 | 01:32 PM
Default Re: h22a turbo question (BoostedH23a1)
oh to answer your question dont go above8-9 if u want it to last little while.
Old May 16, 2003 | 01:51 PM
93H22A's Avatar
safe = 7 psi, run higher octane when possible, not octane booster..
sleeves are made out of fiber reinforced material so upgrading pistons with rings etc will wear out that FRM coat. therefore needing it to be sleeved.
h22a1 has a closed deck block, and h22a4 has an open deck
withoutlimitslude
Sep 10, 2009 11:33 AM
nigel
Oct 2, 2003 08:42 AM
Bad@$$Blue
Dec 12, 2002 03:28 PM
dvp95
May 15, 2002 11:38 PM
ZColeon
May 3, 2002 01:25 PM
