Hondata
Old May 19, 2003 | 11:54 PM
hatchback's Avatar
Default Hondata
Ok, so I am thinking about getting hondata.
What else will be need for fuel management?
Fuel pump? Injectors? Fuel rail?
Any suggestions? Or is hondata itself suffecient enough?
Old May 19, 2003 | 11:57 PM
RyanAutry's Avatar
Default Re: Hondata (hatchback)
What HP Goals?
Old May 20, 2003 | 12:24 AM
hatchback's Avatar
Default Re: Hondata (RyanAutry)
Enough to land me 12'sec quarter miles daily driven.
Then again it is also going to be a d series, so a lot of boost is going to be needed, with a fully built block.
Old May 20, 2003 | 04:54 AM
TurboSedan's Avatar
New User
Get an AEM FPR, and then you'll need some huge injectors to fuel enough to get to the 12's. I would guess 550cc may not be enough, so go to 720cc so you can run a lighter duty cycle on them. The upgraded fuel rail is a good idea, and the big fuel pump is a must, get the Walbro GSS342. It is the 255lph for FI.
Old May 20, 2003 | 06:24 AM
b20turboic's Avatar
im running a zdyne gold much like a hondata 4B and just have 450 cc's and will hit 12's daily with 255hp pump... id say do the pump and 440-660's and your safe
Old May 20, 2003 | 06:49 AM
PrecisionH23a's Avatar
If you have the money redoing your fuel lines would be a good thing to do as well. Usually after around 350whp you want to run larger lines, such as -6an or -8an feed. Some guys on the board have run -10an in the past.
Old May 20, 2003 | 07:23 AM
DLB1994's Avatar
Default Re: Hondata (GudeH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GudeH23a &raquo;</TD></TR><TR><TD CLASS="quote">If you have the money redoing your fuel lines would be a good thing to do as well. Usually after around 350whp you want to run larger lines, such as -6an or -8an feed. Some guys on the board have run -10an in the past.</TD></TR></TABLE>
i have seen 450whp on stock lines
Old May 20, 2003 | 08:00 AM
DIRep972's Avatar
Smarter than you
you can run stock injectors and fuel pump w/ hondata if u would like.
Depending on powergoals the first thing I would upgrade is injectors and fuel pump. You can run alot of power on stock lines, rail, and regulator. I don't see the point of changing it unless you like complicating things and wasting money or until it starts holding you back from making more power.
Old May 20, 2003 | 08:29 AM
boosted hybrid's Avatar
Default Re: Hondata (DIRep)
I recommend for the 350whp range 600-700cc injector range, Walboro 255lph intake fuel pump, Hondata s100, GM 3bar map sensor.
Aftermarket fuel lines, rails, fuel pressure regulators are a waste of money. Stock fuel lines are sufficient well past 500whp. The fittings and lines are not a restriction to the overall flow of the fuel unless you are running a smaller injectors with super high fuel pressure or super larger fuel injectors 1000cc+ and maxxing them out. The stock fuel rails has worked well past 600whp. The aftermarket ones are for decoration only. If you run 700cc+ injectors you dont need to turn up your fuel pressure. So the aftermarket FPR's are a waste as well.
Old May 20, 2003 | 08:44 AM
hatchback's Avatar
Default Re: Hondata (boosted hybrid)
wow, h-t comes through again!
-saving everything in my notes, thanks again guys!
So do you guys suggest getting the engine management first? I want to do it right the first time, so I dont have to upgrade later..
Old May 20, 2003 | 09:05 AM
Dee's Avatar
Dee
boosted..
Walbro 255lph plus stock fpr = bad juju! If you upgrade the pump you need to upgrade the FPR too.
Old May 20, 2003 | 09:07 AM
Default Re: Hondata (Dee)
I have been doing it for two years now, with zero problems. The fuel pressure goes up 3-4 psi when you upgrade the fuel pump. When i tune the maps I adjust the base fuel pressure to 42psi and its set.
Old May 20, 2003 | 09:30 AM
DLB1994's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid &raquo;</TD></TR><TR><TD CLASS="quote">
Aftermarket fuel lines, rails, fuel pressure regulators are a waste of money. Stock fuel lines are sufficient well past 500whp. The fittings and lines are not a restriction to the overall flow of the fuel unless you are running a smaller injectors with super high fuel pressure or super larger fuel injectors 1000cc+ and maxxing them out. The stock fuel rails has worked well past 600whp. The aftermarket ones are for decoration only. If you run 700cc+ injectors you dont need to turn up your fuel pressure. So the aftermarket FPR's are a waste as well.</TD></TR></TABLE>
i try to tell people this all the time
Old May 20, 2003 | 09:38 AM
crzsomang's Avatar
Default Re: Hondata (DLB1994)
walboro 255 HP or regular 255 with hondata?
Old May 20, 2003 | 09:39 AM
Blue-Civic-Hybrid's Avatar
Loved
I did upgrade my fuel pump and injectors, I just have to work out the bugs still in my fuel system... i think my Wahlbro might be going bad or something..I'll find out soon enough at the end of the week when i get my injectors tested out... i got everything used from a friend...
Old May 20, 2003 | 09:46 AM
DIRep972's Avatar
Smarter than you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dee &raquo;</TD></TR><TR><TD CLASS="quote">boosted..
Walbro 255lph plus stock fpr = bad juju! If you upgrade the pump you need to upgrade the FPR too.</TD></TR></TABLE>
My walbro pump did not change my fuel pressures.
Old May 20, 2003 | 01:47 PM
RyanAutry's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep &raquo;</TD></TR><TR><TD CLASS="quote">
My walbro pump did not change my fuel pressures. </TD></TR></TABLE>
Old May 20, 2003 | 04:47 PM
Dee's Avatar
Dee
The Walbro on my car barely changed my pressure but the Walbros on two of my friends car made them go extremely rich. If nothing else get a fuel pressure gauge so you'll atleast know your pressure.
Old May 20, 2003 | 08:53 PM
crzsomang's Avatar
Default Re: Hondata (crzsomang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crzsomang &raquo;</TD></TR><TR><TD CLASS="quote">walboro 255 HP or regular 255 with hondata?</TD></TR></TABLE>
which one with hondata?
Old May 20, 2003 | 09:00 PM
DIRep972's Avatar
Smarter than you
which one with hondata?</TD></TR></TABLE>
it shouldn't really matter. W/ hondata you shouldn't see pressures high enough to where you will benefit from the "High Pressure" version. But when I bought mine I got the HP version it works just fine. Survived 150psi from my fmu/inline combination for 3 months too.
jeffro_rex
Aug 9, 2002 11:57 AM
BLKCRX
Feb 7, 2002 03:38 AM
thequickest GS-R
Dec 29, 2001 09:38 AM
Seraph0
Dec 25, 2001 11:28 PM
Trajic
Oct 9, 2001 10:37 AM
