are these compression numbers good.
Old May 19, 2003 | 02:49 PM
platinum00's Avatar
Default are these compression numbers good.
je, 8.5.1 pistons
1: 205
2: 210
3: 205
4: 205
seems high to me, but hey at least there solid numbers.
platinum.
Old May 19, 2003 | 04:24 PM
turbo Si's Avatar
Default Re: are these compression numbers good. (platinum00)
DAMN.....I have 8.8:1 and mine is at 130 across the board!
Old May 19, 2003 | 04:41 PM
arsenaldragster's Avatar
Default Re: are these compression numbers good. (turbo Si)
pretty high for low compression pistons.. have you milled the head??
Old May 19, 2003 | 05:12 PM
platinum00's Avatar
Default Re: are these compression numbers good. (arsenaldragster)
so is there a problem. should i be woried.
i belive the head was milled when i had it built. no sure how much.
i could check my notes.
i just took it out for the 1st time and really got on it. car only has 500 miles on it. and 6psi. WOW. really fun. 1st gear is usless. . i need my fuel pump and my new injectors so i can bump this up bit. .
so anyway let me know about this compression. is it a issue.
thanks everyone.
platinum.
Old May 19, 2003 | 05:58 PM
eg6turbo's Avatar
damn those are pretty high...my friends jdm h22a with 10.6:1 was tested 210 across...milled would acount for a little of that...try a leak down and see whats the deal
Old May 19, 2003 | 07:17 PM
platinum00's Avatar
Default Re: are these compression numbers good. (eg6turbo)
is there a way to do a leakdown test myself. or do i need a air compressor..
thanks
platinum.
Old May 19, 2003 | 07:19 PM
eg6turbo's Avatar
yes u do...do a search there is a topic descibing how to do it..
Old May 19, 2003 | 07:24 PM
Quiklude's Avatar
well on my h23 when it blew , i ran a compression test and got 195 195 0 195, minus the zero they were pretty high and im running arias 8.5:1's, now remember that the #'s you get from a compression tester shows you how well the cylinder is "sealing" not what compression ratio you, but with a lower comp ratio you can expect to see slighty lower #'s and vice versa with a higher comp. ratio.
Old May 19, 2003 | 07:43 PM
platinum00's Avatar
Default Re: are these compression numbers good. (Quiklude)
so why did you engine blow. did you have any fuel ...
great. so now im affraid im going to blow my motor.
platinum
Old May 20, 2003 | 01:40 PM
eg6turbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quiklude &raquo;</TD></TR><TR><TD CLASS="quote">well on my h23 when it blew , i ran a compression test and got 195 195 0 195, minus the zero they were pretty high and im running arias 8.5:1's, now remember that the #'s you get from a compression tester shows you how well the cylinder is "sealing" not what compression ratio you, but with a lower comp ratio you can expect to see slighty lower #'s and vice versa with a higher comp. ratio.</TD></TR></TABLE>
well the difference from 8.5 and 10.6 is pretty damn big and having a difference of say 30psi could be the difference in CR but like imentions above do a leak down and see the differnce
Old May 20, 2003 | 01:42 PM
platinum00's Avatar
if the leakdown comes back good.
does that mean i just have a killer engine.
platinum.
Old May 20, 2003 | 05:20 PM
racinskittle's Avatar
If you got the head milled, that would have caused it. Sometimes they put a shim in there to prevent the increased compression. (not sure if they do that for all cars)
skippy33
Feb 7, 2021 05:34 PM
triumph_013
Feb 5, 2013 09:23 AM
JasonST
Jun 8, 2007 11:38 PM
zoom545
Nov 22, 2005 09:04 AM
K20 EG
Jun 17, 2003 11:26 AM
