Just installed Action Clutch....
Old May 18, 2003 | 09:31 PM
dvp95's Avatar
Default Just installed Action Clutch....
I just installed the Action 2MD clutch and Fidanza Flywheel on my h22. I had a hell of a time changing the tranny in my accord chassis, but I have a weird sound coming from what sounds like the tranny. If I am in 1st gear and give it a lot of gas, I dont hear anything. But if I dont give it a lot of gas, it sounds like the engine s bogging, but it sounds like a bearing or something. like from the axles, or maybe from the tranny. I dont know what the heck it is but it scares me. Would it be something wrong with the tranny even if its ok if I give it gas? My setup is a 96 accord, 98 jdm h22, basic bolt ons, and front engine mount insert.
Old May 18, 2003 | 10:22 PM
Sonny's Avatar
Default Re: Just installed Action Clutch.... (dvp95)
Did you top your tranny off with oil? If it's full and you pull the axles out, you'll usually lose about a quart (assuming you didn't drain it beforehand).
Sonny
Old May 18, 2003 | 10:24 PM
dvp95's Avatar
Default Re: Just installed Action Clutch.... (Sonny)
I drained all of the fluids, and replaced all of them. Tranny oil went in after the axles were in. What could that sound be?
Old May 18, 2003 | 10:32 PM
93LSivic's Avatar
Probably just not used to the puck noise from the disc. This is pretty common.
By the way. We have an NX remote bottle opener in stock at the shop----give a call tomorrow. Number is in my sig.
Old May 18, 2003 | 10:37 PM
dvp95's Avatar
Default Re: Just installed Action Clutch.... (93LSivic)
Could be the puck I guess. Its my first aftermarket clutch, so I dont really know what to expect. Its a 6 puck, unsprung disc
Old May 18, 2003 | 11:03 PM
Sonny's Avatar
I have the Action 1MS. It's the single diaphram pressure plate with the 6 puck sprung disk. It doesn't make the noise you're describing, but maybe that's because I have the sprung disk? I dunno, man...I would definitely get more info before you drive that thing too much. Better safe than sorry.
Sonny
Old May 18, 2003 | 11:08 PM
dvp95's Avatar
Yeah, thats what im doing on h-t.
Old May 18, 2003 | 11:12 PM
Sonny's Avatar
Send an IM to 2K_TEG (Kyle) or goto his website: http://www.ks-motorsports.com
They are a dealer for Action clutch and can probably give you a definitive answer since I'm sure they have feedback from many users.
Sonny
Old May 19, 2003 | 05:56 AM
TurboSedan's Avatar
New User
My guess would be that it is the unsprung disc making that sound. Like Sonny said, just IM Kyle.
Old May 19, 2003 | 06:28 AM
Adi Radoncic's Avatar
On Fire!
I think what your experiancing there is clutch chatter, sence the 2md is an unsprung hub clutch there is nothing there to take away the shaking and vibration caused when a clutch is engauging...
Someone please correct me if i'm wrong..
Adi
Old May 19, 2003 | 09:00 AM
dvp95's Avatar
Default Re: Just installed Action Clutch.... (newgsr)
Thanks for the help guys, I didnt want to mess up the car or buy anything that I didnt need. I just emailed Kyle, and waiting to see what he says. Thanks again!
Old May 19, 2003 | 09:01 AM
dvp95's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newgsr &raquo;</TD></TR><TR><TD CLASS="quote">I think what your experiancing there is clutch chatter, sence the 2md is an unsprung hub clutch there is nothing there to take away the shaking and vibration caused when a clutch is engauging...
Adi</TD></TR></TABLE>
I hope you are right, so that I know I didnt mess anything up during the installation
Old May 19, 2003 | 10:20 AM
dvp95's Avatar
Modified by dvp95 at 8:53 PM 5/19/2003
Old May 19, 2003 | 10:17 PM
DohcVtecCrx's Avatar
I have action stage 1 md unsprung and I have no chatter at all. They say the sprung will actually chatter a little more. I never had any strange noises with it either. Unless you slip it it will whine quite a bit.
Old May 19, 2003 | 11:50 PM
dvp95's Avatar
Default Re: Just installed Action Clutch.... (DohcVtecCrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DohcVtecCrx &raquo;</TD></TR><TR><TD CLASS="quote">I have action stage 1 md unsprung and I have no chatter at all. They say the sprung will actually chatter a little more. I never had any strange noises with it either. Unless you slip it it will whine quite a bit.</TD></TR></TABLE>
What kind of whining noise are you talking about? I dont drop my clutch for everyday driving. I like to slowly slip it to keep the ride smooth.
Old May 20, 2003 | 05:51 PM
when you letting it out slowely it will whine. It makes the sound when you do not fully disengage it and it slips. Because it is a 6 puck.
Tjames8864
Nov 17, 2006 08:10 PM
VNTEC
18
Nov 28, 2005 12:37 PM
90LSpimpin
11
Sep 19, 2004 10:13 AM
90LSpimpin
Sep 19, 2004 12:58 AM
hybridcrx
Mar 13, 2002 08:41 AM
