Emanage with turbo do I need map bypass??
Old May 16, 2003 | 09:59 PM
Whooopasss's Avatar
Default Emanage with turbo do I need map bypass??
If I used the greddy emange piggy back, do I still need the map bypass (missing link)???? or will the emange work with out it?
Old May 16, 2003 | 10:44 PM
p0gi's Avatar
Default Re: Emanage with turbo do I need map bypass?? (Whooopasss)
If you use an fmu i would use a missing link. It will be almost impossible to tune without one. If you set up the emanage similiar to the vafc hack then dont use one.
Old May 17, 2003 | 08:51 AM
Whooopasss's Avatar
Default Re: Emanage with turbo do I need map bypass?? (p0gi)
ok.. thanks..
Old May 17, 2003 | 10:34 AM
HulkSmash's Avatar
you can use the greddy pressure sensor. it's a optional part for the e manage.
Old May 17, 2003 | 12:55 PM
Whooopasss's Avatar
Default Re: Emanage with turbo do I need map bypass?? (HulkSmash)
Yah.. I was thinking, I dont want to triger a map cel when I boost. Need to look at the diagram one more time to see where the greddy pressure sensor goes or what it is for.
EF_kid
May 14, 2006 09:47 AM
AngelTeg
May 25, 2005 03:12 PM
redlseg
Apr 26, 2005 07:20 AM
Mr.DC2TurBo
Jan 3, 2004 09:56 AM
Blackcivic1
Nov 4, 2002 04:03 AM
