help with safc please
Old May 17, 2003 | 12:43 PM
civicguy's Avatar
Default help with safc please
i just instaled my safc on my 91 civic pm6 ecu,rc 440,and the car is running super lean,even at idle ,i have tried everything,i can put the safc setting at -1% and is still lean,presure reads -753 hg constant and i check the input 1 volts and reads 2.88 volts,now i had before the smc and the map wire was a different one,is not the same one as safc wiring instructions,can anyone help maybe some setting,like in/out i have them in the pressure sensor at 06/06
Old May 17, 2003 | 12:45 PM
shermanyang's Avatar
Default Re: help with safc please (civicguy)
I would check my settings for you but my car is an hour away from me at the moment. I'm sure someone will eventually help you out.
Old May 17, 2003 | 01:05 PM
civicguy's Avatar
Default Re: help with safc please (shermanyang)
bump,i need help guys
dustinbs144
Jun 1, 2010 05:41 PM
harshhatch1187
Oct 6, 2006 10:22 PM
versatilezc
Jun 7, 2006 07:23 PM
iTR.EX
Feb 5, 2003 11:52 PM
