JG turbo cam in N/A setup
if i have a JG turbo cam in my d16y8, but have not yet gotten a turbo will I lose power with that cam other than the stock one or will i still gain some power even though its not turboed yet?
Re: JG turbo cam in N/A setup (SOHC_MShue)
I would be willing to bet that without a turbo it will take a little from the top and put it on the bottom end. Hard to say without knowing the specs.
Re: JG turbo cam in N/A setup (PseudoSilvia)
i am probably about to purchase a y8 head from "Panda EK" on this board. He sais the head is ported, has a cam gear, jg turbo cam, and 3ang. valve job. I'm just trying to get an idea of what power i would make with this setup. I am planning on staying N/A for a few months until i get the money for the turbo. I am not sure of the specs on the cam though.
dont put the head on untill you go turbo unless you want to loose power. Honda doesn't use a turbo grind cam because it dosen't have a turbo!
Re: JG turbo cam in N/A setup (CivicSoul)
well i don't think i would loose power. He had the head on his car N/A and was planning on going turbo, but never did. He said that he definantely made a good power increase with it.
Re: JG turbo cam in N/A setup (TurbodCX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurbodCX »</TD></TR><TR><TD CLASS="quote">I know this is off topic ,but where did you get that cam at?? and how much??
Brian</TD></TR></TABLE>
Brian,
I have one. I got it from JG directly like 3 years ago. More lift. Rumbles a little at idle but idles nice. My is part #85VT-35.
Here is list of their cams:
http://www.jgenginedynamics.co...2.htm
Brian,
I had a JG turbo cam for my d16a6 and I liked it. It didn't breathe as well on the top end, but it had a **** load more torque down in the lower rpms.
[QUOTE=SOHC_MShue]ladysman do you know how well that cam would work for
It will work fine. I was NA for 3 months with it. Runs fine. Son't worry about it and save money for the turbo kit.
Rhythm Racer
07-16-2003 08:14 AM
