OEM exhaust gasket & boost?
Anyone running the OEM exhaust gasket with boost (either high or low boost)?...or are people using Mr.Gasket copper gaskets instead?
Re: OEM exhaust gasket & boost? (XES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XES »</TD></TR><TR><TD CLASS="quote">Anyone running the OEM exhaust gasket with boost (either high or low boost)?...or are people using Mr.Gasket copper gaskets instead?
stock for me, seems to work fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XES »</TD></TR><TR><TD CLASS="quote">Any higher hp cars?</TD></TR></TABLE>
What is mine not worthy?
Re: OEM exhaust gasket & boost? (b16ahybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16ahybrid »</TD></TR><TR><TD CLASS="quote">What is mine not worthy? </TD></TR></TABLE>
...that's not what I meant ....I was just wondering if an OEM would be good at 22-25psi and 500+whp. I was running a copper one last year but I need to replace it and was wondering if stock would do.
...that's not what I meant ....I was just wondering if an OEM would be good at 22-25psi and 500+whp. I was running a copper one last year but I need to replace it and was wondering if stock would do.</TD></TR></TABLE>
ok, just checking... ...
I don't see why it wouldn't work with that much boost, it is metal. I don't have any factual knowledge for you though just oppinion.
LOL........stock for me but i am not in the 500 hp club
a stock should work fine...... unless you use a specific gasket which drops compression, as long as its sealed up right it should work. Aslong as its torqued right a gasket is a gasket.......
jarven093
03-03-2007 10:39 PM
