Tial WG users..problem with the fire ring...need your input
Old May 19, 2003 | 05:09 PM
Cramerox's Avatar
Default Tial WG users..problem with the fire ring...need your input
I blew a gasket the other day...replaced it and blew again. When i had the WG off, the fire ring was not sitting flush to the mating surface of the WG. I was able to push it up and then it would sit flat..but the WG was pushing on the ring.
If i remeber correctly the ring is suppose to sit flush...
what do you think my problem is?
Its a 35 mm tial WG
Marc
Old May 19, 2003 | 05:41 PM
Cramerox's Avatar
Default Re: Tial WG users..problem with the fire ring...need your input (Cramerox)
up please...^^^
Old May 19, 2003 | 05:44 PM
Flamenco-T's Avatar
the smaller diameter goes to the WG side, the larger ones goes against the manifold/elbow side
stan
Old May 19, 2003 | 05:47 PM
evoeone's Avatar
Default Re: Tial WG users..problem with the fire ring...need your input (Flamenco-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T &raquo;</TD></TR><TR><TD CLASS="quote">the smaller diameter goes to the WG side, the larger ones goes against the manifold/elbow side
stan
</TD></TR></TABLE>what he said, its gott abe banged in, *** teh gaskets they suck, i had the same problem as you, flipped it, bange dt in and worked great
Old May 19, 2003 | 05:56 PM
Cramerox's Avatar
stan
right right i know that part.... but i was able to fit it in with out banging it in when i first got it....but u think i have to bang it in now?
Old May 19, 2003 | 06:06 PM
TurboSedan's Avatar
New User
It should stick out a tiny bit from the edge of the bottom, but the important part is to make SURE that it is even and only sticks out the same amount all the way around. Also, make sure you do not fully tighten one side before tightening the other. Do a little on each side at a time, that way you will get a better seal.
Old May 19, 2003 | 06:15 PM
intekragsr's Avatar
Default Re: Tial WG users..problem with the fire ring...need your input (TurboSedan)
I havnet used a gasket on the manifold-wg or wg-dump for over a year. I had no leakage problems.
Just screw the gaskets.
Old May 19, 2003 | 08:41 PM
Cramerox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboSedan &raquo;</TD></TR><TR><TD CLASS="quote">It should stick out a tiny bit from the edge of the bottom, but the important part is to make SURE that it is even and only sticks out the same amount all the way around. Also, make sure you do not fully tighten one side before tightening the other. Do a little on each side at a time, that way you will get a better seal. </TD></TR></TABLE>
it should stick out a little from the bottom? like how much? mine is sticking out about 1/16 to 1/8th but from what i remember, it was completly flush when i first installed it.
i can get the ring flush when i push down on the ring...but the WG diaphram pushes it back....you think i have a probem with the WG? maybe the spring?
anyone else experience this?
Old May 19, 2003 | 08:44 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cramerox &raquo;</TD></TR><TR><TD CLASS="quote">
No your fine, I've also ran with no gasket for a while with no problems.....
Old May 20, 2003 | 04:55 AM
TurboSedan's Avatar
New User
Default Re: Tial WG users..problem with the fire ring...need your input (b16ahybrid)
Yep, it sounds like yours is ok, just make sure it is even all the way around and not crooked.
Old May 20, 2003 | 06:23 AM
Tinker219's Avatar
no gaskets here
Old May 20, 2003 | 08:11 AM
94turbolude's Avatar
sounds good they should stick out some but when you tighten them the ring is seated to the flang with pressure on it and that alows a better seal.
Old May 20, 2003 | 09:36 AM
SiR Kid's Avatar
New User
That's how it is designed to work. The little ring is supposed to act as the "valve seat" when it's tightened down on the manifold. By being SLIGHTLY oversize, it forces the valve to always be under pressure against something other than the housing... Sort of a self correcting seat.
Old May 20, 2003 | 01:27 PM
Cramerox's Avatar
Default Re: Tial WG users..problem with the fire ring...need your input (SiR Kid)
guys thanks alot for all your help...I really apreciate it.
Marc
greasemonkee
May 28, 2008 07:58 AM
eg crunkmonster
Jul 24, 2006 05:13 AM
Metal Head
May 4, 2006 05:43 AM
program
Apr 15, 2006 04:26 AM
KiNG $h!t
Sep 23, 2003 02:08 PM
